1960 F-100 223 generator to alternator
No biggie. Recommend you use a 1965 - 1972 Ford alternator with a standard external regulator. This is the most economical route to go. Need to locate usable bracketry and attempt to match pulleys. Don't know if 223s were made in 1965 and later when Ford went to alternators. May have to fabricate brackets. Wiring is no problem. Check the old posts in the "electrical" section for instructions. If you can locate all the mechanical parts I'll be glad to describe the wiring. An alternator really is the way to go.
Good Luck
Good Luck
... Recommend you use a 1965 - 1972 Ford alternator with a standard external regulator. ... Need to locate usable bracketry and attempt to match pulleys. Don't know if 223s were made in 1965 and later when Ford went to alternators. ...
Anyone know if the bracket from a 240 would fit on my 223?
Cal
I used a one wire alternator from a GM on my 223. Used the stock bracket and made spacers to make it line up with the crank pulley. I am not a great electrician so this unit was perfect for me. A 10 gauge wire goes to the battery and a 16 gauge wire goes to the ignition switch.
my local electrical rebuilder has a regulator that bolts to the back of the Ford alternator and I have one of those on my 56. It cost about $18. I was at the junkyard when the got in a car with the new/rebuilt GM alternator and I bought the whole thing for $15. Either way works.
I wound up going with a GM alternator. (The one that fits a 1975 GM pickup.) I'm in the process of making up a bracket, as the generator bracket hits the mount on the alternator in the wrong place to be able to just use a spacer. The bracket turns out to be pretty simple, I'm using three chunks of 1.25" angle from the local ACE Hardware. Three cuts with the hacksaw, 6 holes to drill--4 if you have a welder. I can post a sketch or more info if anyone is interested.
Wiring is next, looks to be pretty staight forward.
Ed, where did you make the connection to the idiot light?
Cal
Cal
Cal
Cal
1960 F100
08-28-2007 09:54 PM
T.J.
05-18-2002 08:09 AM
