Tennessee Chapter Join Chapter Leader: harleymsn
G-II (or G-2) I have the perfect powerplant for it now...
Old 12-22-2006, 05:34 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
I traded my old wore out flatbed F250 for a heavy duty F350 frame with an EFI 351W on it.
Needless to say - it has a TRUCK EFI system (which has a lot more flow than a Mustang system).
Things are shaping up nicely.
~Wolf
Old 01-11-2007, 06:34 PM
amish77's Avatar
amish77
amish77 is offline
still, just a 351w. I'd rather have a 400 or a 351M for the longer stroke. Better than a 302 or a 300 though.
Old 01-11-2007, 08:33 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
The disadvantages of a 351C or 400M are that it is a much heavier block, and bigger physically. If I go to a big block build, I'll run right around the midblock class and go straight after a 460 let out as far as it can go.I had a 351M at one point courtesy of a '73 Grand Torino. Factory four barrel, four bolt main, the whole nine. The S.O.B. nearly bent a cherry picker...
If I ever go there again, I want it ALL!
In the meantime, I have the engine on the deck, and the heads are coming off tomorrow. THEN we'll know what kind of shape it's really in...
"Any man who tells you that an engine he is getting rid of has low miles on it and runs perfectly is full of crap!"
Old 01-14-2007, 05:39 PM
alabamabuddog's Avatar
alabamabuddog
alabamabuddog is offline
I know where theres a 71 460 just sitting, Im wondering if I can graft on fuel injection.
Old 01-14-2007, 06:35 PM
maples01's Avatar
maples01
maples01 is offline
You need to give the 335 series engine forum, there is a guy who built a 400, and has injected it, NO they aren't a big block and don't weigh near as much either, far better to build because of it. The modifieds have a taller deck, but other than that, they are still the size of a Cleveland, so will drop in where a Windsor came out withaout heavy loss of room like a 460. I beat a friends built 302 with a stock 400 in a T-bird, supprised me greatly, ugly tank would go.
You can use the 90's 460 heads and FI system to make the older block fuel injected, you definately want the newer heads, the 71 will likely have sodium filled exhaust valves, designed for regular leaded gas.
Old 01-14-2007, 06:40 PM
alabamabuddog
From what I understand the older heads flow much much better. I think I could just swap the valves and be ok.
Old 01-14-2007, 07:47 PM
maples01's Avatar
maples01
maples01 is offline
Compression would be too high, require use of high test gas, and the late model EFI stuff may not direct fit those heads.
Old 01-15-2007, 06:42 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
I'd still like to collect a 460 - and yes the valves can be redone (guides & seats included).
But for now I'm on hold pending a clean-up of the financial disaster my estranged created. TRANSLATION: I trade stuff, clean house, and work with what I have right now.
AZAV8
04-08-2016 09:13 PM
joefritz25
39
01-27-2016 08:10 AM
heber_g
Exhaust Systems
02-18-2011 05:00 PM
64fordf100292
09-26-2007 02:12 PM
RRSmith2005
08-11-2005 02:22 PM
Quick Reply: G-II (or G-2) I have the perfect powerplant for it now...
