New Magellan Brandmotion GPS for F-150 dash
Dear LewPoberezny,
Thank you for asking! I am pleased to report the installation of the Navigation system is an easy one! It includes no cutting, splicing, or drilling.
You will need to remove the faceplate covering the radio etc., as well as the coin tray. The Navigation system will go up top replacing the coin tray and will plug into your vehicle via wire harness in the back of your radio. Once that is accomplished, you will snap the faceplate back in place and you are ready to go! I do suggest trying to do this outdoors as satellites, which they must locate in, run the system itself order to operate.
Originally Posted by LewPoberezny
Has anyone installed this new Brandmotion unit? I am looking for any feedback.
I just installed one, and it took only like 5 minutes and the thing is sweet I highly recomend and fyi- you can purchase one brand new on ebay for about 450 that's where I got mine so if your gonna drop money on nav my recommendation is to spend a little extra and get that factory look and not only that you will greatly improve resale where as a non factory nav would probly not
it comes off easy, seems like it is going to break, but does not. mine has been off literally dozens of times.
open the ash tray, pull the radio bezel with a quick tug at the bottom edge exposed.
there are 3 sets of clips, bottom, middle, and top
just walk it up, pulling the bottom first, then pulling half way up to get the center ones and then the top
then unplug the passenger airbag light and swing the bezel to the side
now the tray has two screws exposed, the rear of the tray is just tabs
it lifts right out.
I think i have pics. will post if I do
Ramb
it lifts right out.
Ramb
