Alternator had gone bad. So here it is, Friday before Christmas and all the warehouses tthe dealer geta parts from and other dealers either did not have a Fomoco part or were closed.. All of them are closed until after Christmas.
I got a loaner under the warranty, no charge. A brand new Taurus. I feel like I'm in a shoebox after driving the truck.
I'm going to go into withdrawl. My baby will be gone for almost a week!!!!
My '05 EX had the Alternator die as well, after only 40k miles.
The high-desert dealer would not cut me any slack on the 36K warranty, and would not have had another one except I went to the parts dept. and ordered one at 9am. I was on vacation and needed it to be fixed.
$379 for the Alternator and $180 to install it.
Rape.
I installed a $12.99 volt meter that plugs into the power-port on the dash, very cool, and noticed the voltage still getting low in the morning.
I just (yesterday) replace the passenger side battery, it tested out internally shorted. I think maybe it had been making the alternator work too hard for a long time.
You might check into the same possibility.
_____________________
Quietman www.roenation.com
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers,
LANDYOT Generation II Radius Rods, Ford factory hood insulator
Had the same problem with mine. Dealer finally found the problem, a CAM sensor, whatever that does. Told me that they would only be able to find it by having it towed in without restarting it. Restarting cleared any codes they might find. It finally did it in the driveway, sent it away right then. Haven't had that problem since.
Cam Position Sensor. Very common for them to go out. So much so, that it's widely talked about on the PSD boards to the point it's become "common knowledge" for those that visit UBB's on a regular basis.
Do a search on "CPS" and you'll find tons of reading. They are very easy to change out, and a lot of us carry a spare in the truck with us, just in case. Ebay is the cheapest place you can get the CPS, still in the Ford OEM package.
Just curious, how much did the dealership charge you for the diagnosis and replacement of yours?
Stewart
__________________
1999 F150 Lightning
- WMS built block
2002 F250 PSD SC 4x2
- 4" turbo back, AFE Stage 1, JW valve body, AC codes, Live Tuned by Jody
2000 PSD Excursion 4x4
- John Wood tranny, DP-Tuner, AFE, MBRP 4", BDP 1.0, O/boost Annihilator, Pre-Pump mod, Gauges, V & B code springs, Hellwig rear sway
As the previous owner of 14 Taurus' I can say with confidence that I would be fighting the temptation to end my life if forced to surrender my Ex for a bull.
__________________
01 Excursion 4x4 V10
95 F150 300 2wd
98' Grand Prix Drag Car
An excessively large gas bill.
Every time I browse through post titles and see this one I think it's something like your ex wife died. Hopefully you can get it fixed.
__________________ Chris, Official Slackmaster #9
2003 F350 CC 4x4 Isspro Gauges, Zoodad,straight piped Bill Cosby - "A word to the wise ain't necessary - it's the stupid ones that need the advice." BC Chapter Member/Leader JOIN THE BC CHAPTERHERE
