Steering Gearbox Adjustment? - Ford Truck Enthusiasts Forums
Old 12-20-2006, 04:58 PM
masseysbronco's Avatar
masseysbronco masseysbronco is offline
masseysbronco is starting off with a positive reputation.
Question Steering Gearbox Adjustment?
I know this has been disscused before, but I can't locate a thread that has the proceedure in it. How do i tighten up the worm gear? In which direction do I turn it if i'm standing in front of the truck? I know to make very small adjustments at a time, but I can't remember all the details and it is time to tighten it up again. Everything else is new and in good condition.
Old 12-20-2006, 09:23 PM
helirich helirich is offline
helirich is starting off with a positive reputation.
Loosen the lock nut. I believe you turn the screw clockwise. Than retighten the lock nut. I do it a quorter turn at a time. The lock nut can be a knuckle buster.
Old 12-20-2006, 10:20 PM
Redbob Redbob is offline
Redbob is starting off with a positive reputation.
Loosen the locknut with a box-end wrench, soaking it first with some Liquid Wrench; tighten it no more than a quarter-turn at a time AND TEST IT OUT FROM LOCK TO LOCK!
See, you're most likely doing your adjustment in the center of the travel, where there's the most wear. If you tighten it too much, it'll bind up at full left or full right turn, where there is relatively little wear and things are likely mucher tighter already.
Best procedure is to do like the shop manual says and jack both front wheels off the ground so you can "feel" what you're doing.
Don't get greedy; this isn't a rack & pinion box, so it's never going to feel really tight.
Old 12-21-2006, 01:58 PM
Allright, i'm going to give it a try, just wanted to make sure I know what i'm doing first.
Old 12-21-2006, 10:09 PM
RMS94 RMS94 is offline
RMS94 is starting off with a positive reputation.
Old 12-22-2006, 01:33 PM
bronco521's Avatar
bronco521 bronco521 is offline
bronco521 is starting off with a positive reputation.
if you get it set too tight the steering won't return to center well on its own.just sneak up on it.
Old 12-22-2006, 06:00 PM
33boggers 33boggers is offline
33boggers is starting off with a positive reputation.
My steering box has too much play it it. noticed it last year when I bought the truck. Tighting up the worm gear wont make it better just harder to turn. I need a new gear box
Old 12-22-2006, 07:02 PM
I tightened the gear in about 1-1/4 turns and 90% of the slop disappeared and no harder to turn either. Just turn the gear in 1/4 turn at a time. Test drive between turns. When the slop doesn't get any better then stop.
Roger
Old 12-22-2006, 07:25 PM
BroncoRoadKill's Avatar
BroncoRoadKill BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
Like everyone else said if tighting it makes no difference in slop but just makes it harder to turn then your sector and worm are worn out.
which way to adjust rear drum brakes? 2002sport 1987 - 1996 F150 & Larger F-Series Trucks 6 09-07-2014 07:10 PM
MBRP Eff Up Times Three davlan88 6.0L Power Stroke Diesel 8 08-17-2013 09:41 AM
Ford Drum Brake Adjustment nmventure 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 01-21-2011 10:42 AM
Tightening up loose steering. chrissmallwood 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 05-30-2010 02:16 PM
2003 F350 door rattles jet5545 6.0L Power Stroke Diesel 9 10-28-2008 12:33 PM
Tags
56, adgustment, adjust, adjustment, adjustments, antonio, box, f150, ford, gear, gearbox, lash, san, screw, steering, texas
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
