What next or will trans not hold it
I have a 97 PSD. Truck runs great. Has 3 in down pipe followed by straight pipe, cold air intake with K-N open filter. Edge evolution programmer and ez edge. Shimmed fuel pump. Smaller turbo housing. EGTs stay low no problem there. Its an automatic with 3.55 gears in rear end. So my question is will the trans hold any more towing a loaded gooseneck trailer or time for a HD transmission? Is there anything thats better than Edge?
Originally Posted by tjbeggs
from what I hear there are a few things better than the edge. A chip from either dp-tuner or tony wildman will be tops! I would address the transmission. A valve body from BTS would be the best bet. Then a chip from dp-tuner and tell him you have the VB and he will set you right up.
Hello,
We have a high performance PTS Valvebody for your vehicle. We also have programmers. Please give us a call for more information or visit our web site.
Mike,
LEVEL TEN TECH
973-827-1000
http://www.levelten.com/store/index.htm
on
The only problem you may have is the torque converter. The stock converter cannot handle the extra load, and the clutches can and will eventually burn up. The new valve body will help prolong the life of it though. I just did the entire transmission with an ATS unit, quad clutch billet converter, new valve body, and kevlar clutches. The truck was a whole new beast.
rebuild it
any proper beefing of the trans will help out. and yes the hard parts fail at any time and a valve body will only help as much as what the worn parts inside can handle.
with what your planing on doing and have done the unit will not last much longer without proper help. it's not a hard unit for any good diyselfer and we can supply you with all the parts you will need. and a great manual on doing it.
give us a call make sure you say your from fte .
ya Im expecting to do a torque converter soon. The truck had a rebuilt trans in it when I got it with 15K on the trans. But they didnt replace the TC so been looking at those also. Would like to do a complete trans and TC swap but thats not in the pocket book. So doing what I can afford now to prolong the life of the trans right now.
