differential fluid level on 02' explorer - Ford Truck Enthusiasts Forums
Old 12-19-2006, 10:01 PM
twisted limb twisted limb is offline
twisted limb is starting off with a positive reputation.
I took the fill plug out on my rear diff. of my 02' explorer and fluid beagn to pour out so I quick put it back on.I was on perfectly level ground.I was under the impression it should be just at the fill hole.I am going to change it and the book calls for 3.25 pints of fluid plus the friction modifier.Any insight on why the fluid level is so high?
Old 12-19-2006, 11:22 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
there is a big plug, maybe a 3/4 inch square drive head, on the back of the pumpkin that is the drain plug... on the driver side toward the front nearer to the drive shaft is a smaller plug about half way from the bottom to the top of the case. it has a 3/8 inch suqare drive hole to remove it. the small plug is the fill, the big plug is the drain hole. it does hold almost 2 quarts of synthetic 75w 140 oil and 7 ounces of the friction modifier.
Old 12-20-2006, 06:01 AM
Thanks-I see the drain plug and the fill plug is on the back side just above and to the right of the drain plug.I was just wondering why fluid would run out of fill plug?It should not be pouring out of there unless it is overfilled, correct?
Old 12-20-2006, 10:21 AM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
Had you just driven it, or did you check it cold?
Steve
07 explorer tranny fluid arimaman Explorer, Sport Trac, Mountaineer & Aviator 5 04-12-2014 11:47 AM
Checking and Adjust Trans Fluid Level 5R55S V6 Models makuloco2000 Explorer, Sport Trac, Mountaineer & Aviator 0 11-11-2013 10:30 PM
Degas Overflow Tank Spitting Coolant BASSHUNTER 6.4L Power Stroke Diesel 33 07-30-2010 11:03 AM
2002 Explorer transmision F250WVO Explorer, Sport Trac, Mountaineer & Aviator 6 11-22-2009 05:06 PM
Filling A4LD xlt4wd90 Aerostar 14 06-20-2006 11:46 AM
Tags
2002, 2004, 2005, changing, check, diferential, diff, differential, explorer, fluid, ford, front, level, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
