1988 f150 Brake air pressure leak??
Originally Posted by ricalbuq
what exactly does that mean? Where is the brake booster. Forgive the ignorance.
ricalbuq
ricalbuq
Boosters play a very important part in the flow of force though the braking system. The illustration shows a vacuum booster mounted just before the master cylinder. The connection to the brake pedal linkage is shown sticking out the rear of the booster.
The booster makes it possible for people with all degrees of leg strength to activate the brakes effectively. The booster adds a vacuum or hydraulic boost to the force produced by the driver's leg and the leverage of the brake pedal. All these forces combined push on the master cylinder. With the boost working, a much lower force is required to operate the brakes.
On my 89 4x4 seems to be doing the same thing but..
When I depress the brake pedal I hear an air sound in the cab as if the brakes are losing some type of air pressure. This truck does not have air brakes and prior to my purchase I was told that the master cylinder was replaced. Any ideas??
ricalbuq
ricalbuq
My is making a heck of a whooshing sound of air under the dash, only when engine running and pumping the brakes.
Sounds like a booster getting ready to let go? What are some braking warning signs that it is about to quit working?
I just replaced the master cylinder a few months ago, then over the weekend the a rear wheel cyclinder let go. So I repalced both wheel cylinders and shoes, bleed the system and now I have the ABS light. I went to the ABS valve and bleed it a couple times no air, soild fuild. The light was never on until after the master cylinder was replaced but before the wheel cylinders let go.
Ideas? Thoughts?
Thansk Mike
Robert 17
07-03-2008 12:07 AM
ricalbuq
12-19-2006 04:58 PM
