Fuel pressure spec? - Ford Truck Enthusiasts Forums
Fuel pressure spec?
Old 12-19-2006, 05:47 PM
TrueBlue1 TrueBlue1 is offline
TrueBlue1 is starting off with a positive reputation.
Fuel pressure spec?
Anyone know what the fuel pressure spec. at the rail is for a 2001 5.4?
Old 12-20-2006, 09:48 AM
Quote:
Please help...
2001 f150 H.D. Supercrew, 5.4L "L" code.
65,000 Miles
No MIL\CEL light or codes
She won't start. ran fine the last time I drove it, which was 2 days prior. Cranks over fine and hits occasionally, but will not run. It sounded like it was out of gas, so I tested the fuel pressure at the fuel rail and found 40psi during the 3 second pump-up when you first turn the key and a drop to 35psi after the 3 secs. which held with key on or off. Is this enough pressure?
Old 12-20-2006, 09:51 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
That's enough. It should be 30-45 psi.
If you hold the throttle open a bit does it make any difference? Have you tried holding the throttle to the floor in case it's flooded?
Original spark plugs?
Old 12-20-2006, 10:09 AM
Holding the throttle open 10% or so is the IAC test correct? If so it didn't work. The plugs were replaced at 60,000 miles with OEM (65,000 Miles now). I haven't tried throttle to the floor but the truck has been sitting for days between start attempts. What happens when the cylinder head temperature goes out of range? (Had a CEL at first but did not come on a gain after reset)
Old 12-21-2006, 08:52 AM
The only other thing I haven't checked out is my K&N filter. I'll see if it fires without it (duh!) maybe it's clogged?
Old 12-21-2006, 10:46 AM
Racerguy's Avatar
If the air filter is plugged enough for it not to start you would have noticed that it had no power for quite a while before it finally stopped running.
I would probably pull a plug or 2 and take a look to see if you have good crisp spark and make sure they aren't flooded.
Any chance you just filled the gas tank up and got a bad load of gas?
If you scan it with the engine cold you might get a CHT out of range code. Can you monitor live data with the scan tool you used?
Old 12-23-2006, 10:39 AM
I got it to run. After extensive reading on the iatn site I learned about what to try if you think it's flooded (among many other things) and it worked. Why it flooded? Your guess is as good as mine! Maybe IAC sticking?
P.S. Thanks Racerguy, for helping me get pointed in the right direction
TrueBlue1-CARBLOVER!
Torque specs, flywheel and pressure plate bolts cadunkle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 11-19-2016 07:59 PM
Fuel Sys Pressure 01 4.2L scottie2hottie 1997 - 2003 F150 2 10-08-2014 11:36 AM
Blue Spring Cap Bolt Torque Spec Striderwv 6.0L Power Stroke Diesel 1 09-28-2011 10:16 AM
ICP Pressures 73strokin 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-14-2011 09:31 PM
fuel pressure damian03 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 12-30-2003 12:06 AM
Tags
2001, 2008, 38, 46, 54l, 96, f150, ford, fuel, hold, pressure, spec, specifications, specs, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
