need diagram or pictures...
i finally got my truck all back together today, it started like new. i had the problem with the clutch fork.....remember? well i got the new pin for it, and put it on. i thought i had the clutch fork in properly, but i don't. when the truck is running it won't go into any of the gears. when the truck is off it goes into gear fine. if i put in gear with the motor off, then start the motor it won't come out of gear. i must have my clutch fork in wrong, or the throw out bearing is not on right. i am not sure which, but that would explain why my clutch pedal pushes in so easy, and it takes two springs to make it return. SO, if anyone has any pictures or diagrams of a 1968 f100 2wd 3 speed manual trans. column shift they could send my way i would be forever grateful. i have to get this truck out of my buddies shop cause he has a roll cage job coming in this weekend. thanks a lot guys. -tony
dyingtolive
15
03-29-2012 11:56 PM
