pretty sure tony buys the chip blanks from an electrical supplier then writes his own programs to them. pretty sure most do this.
heck they might even buy the blanks from ts but not sure.
spoke with ATS R&D dept today about the turbo, they said it will be fine with 160cc injectors.Injectors in the 200cc range will require turbo change.Now i have to decide on whos injectors to use.
i prefer swamps. i know all the guys that work there and they are extremely helpful. they dont really have "stages" though. they build the injector to flow what you want. i have 180'sand a custom 6 pos chipfrom them. all i can say is wow! and if i stay off the pedal get good milage. they can help you figure out what you need and have custom chips and programs for their injectors.
I think that wastegated housing will be pretty sweet with the larger injectors, especially since it will help keep your boost numbers lower which will make your turbo last alot longer.
