tranny taking long to engage
Old 12-18-2006, 10:34 AM
F-250 diesel's Avatar
F-250 diesel
F-250 diesel is offline
Question tranny taking long to engage
ok, i have a 2002 f-150 with the 5.4 and auto trans and when i go to put the truck in drive or reverse, it kinda takes a little while before it goes into gear. like when i put it into drive, it will sometimes take a couple seconds before it actually goes into drive. my dad has a 2002 f-150 as well with the same engine and trans except his goes right into gear as soon as you put it in....is there a linkage i can adjust to help that?
Old 12-18-2006, 01:16 PM
92merc's Avatar
92merc
92merc is online now
How many miles since the last transmission fluid change? If I remember right, Ford recommends every 30k miles a change-out.
Plus, you should just check the fluid levels...
Old 12-18-2006, 04:28 PM
F-250 diesel
well i bought the truck used not to long ago with 37,000 on it, they said they did a flush but when i checked it i could tell they didnt, i made them do one and it still does it. is there a solenoid or something that engages it into gear?
