1960 Clutch Master Cylinder Rebuild???
Old 12-18-2006, 09:12 AM
samahi72's Avatar
samahi72
samahi72 is offline
My master clutch has gone bad. Can they be rebuilt with a kit? And if so, is there some place special to buy the kit? Thank you
Old 12-18-2006, 09:35 AM
bobbytnm's Avatar
bobbytnm
bobbytnm is online now
Roast em' if you got 'em
Received 3,836 Likes on 1,835 Posts
Yes, they can be rebuilt with a kit. You should be able to get the kit most anywhere. I'd try NAPA first. Either that or look in the yellow pages for Brake & Clutch.
The kits are pretty basic. Its a quick and easy rebuild
Bobby
Old 12-18-2006, 10:06 AM
exidenick's Avatar
exidenick
exidenick is offline
The NAPA # for the kit is 211 it should be $13.49
For a new master # 25517 $92.49
Old 12-18-2006, 09:52 PM
angus's Avatar
angus
angus is offline
The problem is that if the seals go, that's probably because the bore is pitted. And you can't hone away deep pits. So, check the bore before wasting money on a rebuild kit.
Old 12-18-2006, 11:17 PM
Fomoko1's Avatar
Fomoko1
Fomoko1 is offline
Received 1,353 Likes on 1,112 Posts
I was lucky on my 57, just needed a clean up with a hone and the kit. There wasn`t any bad rust or pits as the cups gave out from age and use.
Old 12-19-2006, 12:41 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Original Ford Numbers
Clutch slave/master cylinder repair kits 1957-1960 F100-F350
1957/59: B7C-7560-A Clutch slave cylinder repair kit.
1960/62: C3TZ-7560-B Clutch slave cylinder repair kit.
1957/1960: B7C-7578-A Clutch master cylinder repair kit.
gtcrackers
04-14-2015 07:48 PM
gtcrackers
11-08-2014 02:08 PM
Vsanzbajo
07-08-2014 10:14 AM
Jagolet
12-22-2013 08:07 AM
Quick Reply: 1960 Clutch Master Cylinder Rebuild???
