1960 Clutch Master Cylinder Rebuild??? - Ford Truck Enthusiasts Forums
Old 12-18-2006, 10:12 AM
samahi72 samahi72 is offline
samahi72 is starting off with a positive reputation.
My master clutch has gone bad. Can they be rebuilt with a kit? And if so, is there some place special to buy the kit? Thank you
Old 12-18-2006, 10:35 AM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Yes, they can be rebuilt with a kit. You should be able to get the kit most anywhere. I'd try NAPA first. Either that or look in the yellow pages for Brake & Clutch.
The kits are pretty basic. Its a quick and easy rebuild
Bobby
Old 12-18-2006, 11:06 AM
exidenick exidenick is offline
exidenick is starting off with a positive reputation.
The NAPA # for the kit is 211 it should be $13.49
For a new master # 25517 $92.49
Old 12-18-2006, 10:52 PM
angus angus is offline
angus is starting off with a positive reputation.
The problem is that if the seals go, that's probably because the bore is pitted. And you can't hone away deep pits. So, check the bore before wasting money on a rebuild kit.
Old 12-19-2006, 12:17 AM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
I was lucky on my 57, just needed a clean up with a hone and the kit. There wasn`t any bad rust or pits as the cups gave out from age and use.
Old 12-19-2006, 01:41 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Original Ford Numbers
Clutch slave/master cylinder repair kits 1957-1960 F100-F350
1957/59: B7C-7560-A Clutch slave cylinder repair kit.
1960/62: C3TZ-7560-B Clutch slave cylinder repair kit.
1957/1960: B7C-7578-A Clutch master cylinder repair kit.
Clutch master cylinder bleeding gtcrackers 1957 - 1960 F100 & Larger F-Series Trucks 5 04-14-2015 08:48 PM
Clutch master and slave gtcrackers 1957 - 1960 F100 & Larger F-Series Trucks 12 11-08-2014 03:08 PM
Where can I get the rebuild kits for clutch master cylinder and slave for a 59 F100? Vsanzbajo 1957 - 1960 F100 & Larger F-Series Trucks 3 07-08-2014 11:14 AM
73 Ford step van Gruman Jagolet 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-22-2013 09:07 AM
73 Ford step van Gruman Jagolet 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-06-2013 08:20 PM
Tags
100, 1960, 8000, clutch, cylinder, f100, f350, ford, kit, m100, master, rebuild, repairing, slave, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
