Can you disable auto 4wd on Explorer? - Ford Truck Enthusiasts Forums
Old 12-17-2006, 10:25 PM
pilot4x41 pilot4x41 is offline
pilot4x41 is starting off with a positive reputation.
Is there a way to disable the auto 4 wheel drive on a 98 Explorer for testing purposes? I believe there is a module but can't remember where it's located and I don't know if it can be temporarily disabled.
John
Old 12-19-2006, 02:14 AM
koldstart koldstart is offline
koldstart is starting off with a positive reputation.
There is a plug on the transfercase you can dissconnect that will dissable the AWD system. Doing so will only have the rear wheels drive the car.
Lying on your back slide under the driverside door and you will see what I'm talking about. Its a big connector, can't miss it.
Old 12-19-2006, 03:09 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Or, you could just disconnect the brown wire that goes into the T/C case near the output shaft. you would then have 2H and 2L
Old 12-20-2006, 12:26 AM
Thanks for the info I'll give it a try tomorrow.
John
Old 10-01-2012, 04:42 PM
Dai101 Dai101 is offline
Dai101 is starting off with a positive reputation.
First of all sorry for this long necro bump. Secondly i've a 93 Aerostar that has the front differential busted and it cost a good $$$ to fix it and don't have that much at this moment so i ask if this same method can be used to my truck? Any other thing i have to do? Many thanks in advance and again sorry for this bump.
Old 10-01-2012, 06:43 PM
aquanaut20's Avatar
Quote:
I believe your ride has AWD, it is therefore a different kettle if fish and the answer would be, NO!
Old 10-02-2012, 09:51 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
You should ask that question in the Aerostar section. The answer would be very no. If you disable the AWD computer, it will still try to drive the front driveshaft. If you try to disconnect the driveshaft, the van will either not move, or will only move until you grenade the transfer case, which won't take very long at all, maybe a few miles. The AWD Aerostar is designed to drive all the wheels all the time.
Old 10-02-2012, 08:13 PM
impish impish is offline
impish is gaining momentum as a positive member of FTE.
The difference between All Wheel Drive and "Auto 4WD" drive ought to be made clearer.
Auto 4WD uses an electronic clutch which does not engage power to the front wheels until slippage or speed difference is present betwe4en front and rear wheels.
AWD provides power to both front and rear at all times, though the power "split" is not constant.
impish
Old 02-24-2016, 03:06 PM
BLTD BLTD is offline
BLTD is starting off with a positive reputation.
Yes, and this quick fix really works 1997 Ford Explorer E.B. 4x4
This quick fix really works.
Vehicle: 1997 Ford Explorer Eddie Bauer V6 with ( Auto / 44 HI / 44 Low ) located on the dashboard selection ****. It compleatly dissengaged the front differential electronically at the transfer case. The 4x4HI and 4x4Low dash lights flash every now and then but I will connect only them or disconnect them altogether.
Thanks,
Disable Auto-4WD : Ford Explorer Timothy123 Explorer, Sport Trac, Mountaineer & Aviator 1 10-09-2016 11:16 PM
DayTime Running Lights disabling surreyboy 6.7L Power Stroke Diesel 7 11-02-2015 12:07 PM
auto lock disable jocko165 1999 to 2016 Super Duty 7 10-26-2015 06:36 PM
Disable Auto 4wd? 93F250 Explorer, Sport Trac, Mountaineer & Aviator 13 09-11-2014 07:51 PM
explorer "auto 4wd" disable larrybe Explorer, Sport Trac, Mountaineer & Aviator 1 01-06-2004 02:01 AM
Tags
04, 1994, 2000, 4wd, auto, awd, case, diable, disable, disabling, drive, explorer, ford, transfer, turn, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
