, The 2000 F150 started to leak trans fluid on the hwy, from a round seal, not the drain plug, is the trans gone? or is it just a seal?
Please help
chinook forever
Is it leaking from the seal in the rear where the rear driveshaft goes into? If it is, my truck did the same thing, and it was really easy to replace the seal.
[IMG]trans.jpeg[/IMG] If the picture comes out, its the front hole in the bottom of the trans (about 2" in dia.), about 1" from the front flange, it shows in the picture surrounded with black paint.
If the picture does not show maybe you can go by the description.
thanks
Picture didnt work, but it sounds like its coming out the inspection plug like wilber said. Maybe the plug in the torque convertor is leaking? Im not 100% sure where you are talking about though.
Yes, its coming from the inspection plug, does that mean I have to pull the trans out? or at least pull it away from the motor?, I have 2 trucks down for trans!!!
First turn your motor over and check to see if the torque convertor plug is leaking. Then go from there. I would say it sounds like a front seal though, something that may need the trans pulled back from the motor.
