Does anyone know the true factory horsepower and torque ratings for a 351W? - Ford Truck Enthusiasts Forums
Old 12-17-2006, 06:32 PM
ford0625 ford0625 is offline
ford0625 is starting off with a positive reputation.
Question Does anyone know the true factory horsepower and torque ratings for a 351W?
We just recently put a rebuilt 351W in my 85 F150 4x4. It is 1979 model and was rebuilt to factory specs. Can anyone provide me with the factory horsepower and torque ratings for this model Windsor? Thanks a bunch.
Old 12-18-2006, 09:10 AM
paden's Avatar
paden paden is offline
paden is starting off with a positive reputation.
Check out Wikipedia, if this page doesn't help I have seen many others that could help.
http://en.wikipedia.org/wiki/351_Windsor#351W
Old 12-18-2006, 09:57 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1979 351w
As installed in Ford Pickups...
NET HP 156 @ 3200 RPM
NET TORQUE 262 ft-lbs @ 2200RPM
Net HP ratings are relative to weight of vehicle and might vary slightly.
Old 12-18-2006, 07:26 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
A 79 351W is going to be out of a car, and probably have even less power than the specs listed above for an 82-84 2bbl truck engine... The 351W was not installed in trucks until 1982.
Now, if it was re-built to 85 specs with a 4bbl on top, that's a different story again.
Old 12-18-2006, 07:42 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Old 12-19-2006, 01:50 AM
351w....1975////1979
Aren't Econolines considered trucks?
351W first offered in Econolines in 1975.
My reference came from the 1979 Econoline 351W.
The passenger car/truck specs are nearly identical in 1979.
Old 12-19-2006, 06:43 PM
The key terminology is
F-series
vs
E-series
No 351W's in F-series trucks until 1982
Old 12-20-2006, 05:04 AM
Quote:
F-series
vs
E-series
Quite true Sir, but Ford0625 said the engine was from 1979...he didn't say what the engine came from. I looked at both the Econoline and LTD specs, which are similar in 1979, so I went with the E.
My mistake: I should have said..."as installed in Ford vans...."
Old 12-23-2006, 04:57 AM
Smile Thanks for the input!
Hey Number Dummy, thanks for the input. The engine is indeed a Windsor, a 1979 2V originally out of a car probably a LTD. It has a lot of power so the numbers are disappointing and makes me wonder if they were somehow underrated in the late 70's and early 80's due to emissions, etc. I can be idling, and feathering the gas and it will rock side to side as does my 65 F250 with a 390. It doesn't have near that much torque but it seems to do great for what it is. Thanks again for your input.
horsepower rating of 351W ? redwoodlogger 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 12-16-2014 02:52 PM
Horsepower and torque on a 5.8 EFI? Ohioguy 1978 - 1996 Big Bronco 3 09-27-2010 10:47 PM
84 f150 351w horsepower jrmandryck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 06-28-2009 12:12 AM
429 horsepower rating 351m_torque Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 03-20-2006 10:52 PM
Factory Horsepower Specifications for 1985-87 351 HO USAFORD 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-17-2002 12:53 PM
Tags
1979, 351w, 390, 427, 79, 82, 85, a1979, engine, f150, factory, horsepower, hp, put, rating, specs, stroke, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
