Broke Down Distibutor Not Turning on 49 flathead
I'm not familiar with flatheads, but when my 351C did exactly that, the problem was that the pin securing the drive gear at the bottom of the dizzy shaft had sheared. Pull the dizzy, replace the pin, reinstall. Very simple fix. The dizzy is designed so that the shear pin goes before the gears strip out.
Might be the same setup on a flatty.
It is possible that the drive gear has come loose on the camshaft, see attached. (Courtesy Of MacVP's site) #6255 is the dizzy drive gear which is keyed to the camshaft.
Here's some links that are flathead related. (I assume you have the flat V8, not the 6?)
http://www.vanpeltsales.com/FH_web/f...ings_links.htm
http://www.btc-bci.com/~billben/flathead.htm
It is very possible you have a fiber camshaft gear that broke. Personal experience: 12 years ago was driving my '51 the 4 hour trip from my parent's house back to college, after rebuilding the motor, part of the rebuild being a new fiber cam gear. About 90 miles from Columbia, at 60 mph it just made kind of a "puh" sound and was dead. Long story short, the crank grinder apparantly dinged one of the crank gear's teeth, and it chewed the new gear up in under 300 miles. Replaced with an aluminum gear that was chewed (but not failed) within another 300 miles. Replaced both gears again and all was well. I won't go back to the fiber gear any more because of this. At least the aluminum gear made a little noise when it started getting worn and let you know there was a problem other than the cam gear.
Received 1,351 Likes
on
Originally Posted by ALBUQ F-1
Of course, if the aluminum gears made a little more noise, people would think you had a blower, too!
