1951 F1 Cab Mounts
There are a total of 6, if you want to replace them all. Four flat pads and the two links at the rear. Some people have problems with the links, especially the rubber blocks that go between the links and the mount. I did my links one at a time, just jacked the cab under the strong beam that runs across it (under the gas tank). I'm not sure there is any trick to the whole process, other than for the four pad mounts you need to have all of them loose at once or you won't be able to get any clearance to pull out the old and stick in the new.
The careful application of a frosty beverage (or two) sometimes helps the situation also.
When I got my truck, the previous owner had taken a smoke wrench to all of the cab mounting bolts in order to take the body off of the frame (he never got that far) I got the truck and had it running and driving before I noticed that I had absolutely nothing but gravity holding theh body on....ooops
Installing the mounts was fairly straightforward. As Ross stated, just move around the truck one at a time. Use a floor jack to raise the cab slighty at the corner you're working on and slip them into place. The links in the rear might take a bit of wiggling but they aren't bad.
Bobby
Bobby
