F-600
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
Received 1,351 Likes
on
bobj49f2, I found that out when I tried using an F800 steering gear box on an F600, the pitman arm didn`t even come close to fitting. I don`t know if it was possible to use the larger pitman arm as on the other end it might be a different size as well. I gave up as it seemed too much trouble at that time.
The F-600 box is the way to go, but, If you are running the stock engine (v-8) the canister oil filter is extremely close to the larger box.
The f-600's came with an oil filter 90 degree adapter to move the oil filter away from the box.
If you go this route and need the adapter I have them. PM me and we will work something out.
Another note: The 53-55 boxes are the same, but the 56 has a 1" shorter steering shaft and when used with the 53-55 steering wheel it makes for an uncomfortable fit between your stomach and the steering wheel.
Kevin Bigwin
Kevin Bigwin
Steve
07-07-2014 08:27 AM
erinaldi
01-20-2009 07:34 PM
rustyrelic
04-23-2008 11:46 PM
wademo
11-25-2007 05:46 PM
