Timing Marks on 2001 Ranger 3.0 - Ford Truck Enthusiasts Forums
Old 12-15-2006, 02:54 PM
BNSFMoW's Avatar
BNSFMoW BNSFMoW is offline
BNSFMoW is starting off with a positive reputation.
I'm getting ready to change my CPS and synchronizer. I cleaned off the damper and found the timing marks on it but I'm not completely sure what to line them up with on the timing cover. There isn't the usual kind of pointer I've seen before. Just to the right of the crankshaft sensor is a sort of triangular nub cast into the timing cover. Is this the pointer I need to line up with my TDC mark? I checked in the Haynes manual and they don't show any pictures or give any kind of description.
Thanks for any help.
Old 01-05-2007, 10:55 PM
amish77's Avatar
amish77 amish77 is offline
amish77 is starting off with a positive reputation.
in general a triangle mark is the pointer that you use. If the rest of the surface is clean and there isn't another mark then I'd say use the cast mark you're describing. Just not sure why it's on the crank and not the cam, which is where I'm used to seeing them.
Timing marks?????? 1968f100 Ford Inline Six, 200, 250, 4.9L / 300 28 08-18-2016 11:34 AM
harmonic balancer & TDC off abyars111 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 10-04-2014 06:57 PM
351W timing cover. No timing pointer? mnewbolds 1967 - 1972 F-100 & Larger F-Series Trucks 7 09-15-2014 05:19 PM
352 Timing Mark Gregory Glaser FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 09-02-2012 08:38 PM
1990 4.9 300 inline 6 timing question Supergordo Ford Inline Six, 200, 250, 4.9L / 300 2 11-13-2011 11:36 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
01, 1996, 2006, 30, 30l, crankshaft, engine, ford, mark, marks, pics, pointers, ranger, tdc, timing, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
