The dreaded oil-filler cap condensation! - Ford Truck Enthusiasts Forums
Old 12-15-2006, 02:48 PM
bryan_1980 bryan_1980 is offline
bryan_1980 is starting off with a positive reputation.
Thumbs down The dreaded oil-filler cap condensation!
Well, while having my oil changed, some condensation was discovered on the oil filler cap. I've heard this is often a sign of a head gasket failure. However, I have not discovered any water/coolant on the dipstick. It also seems to be running at normal temp., and it's not using any coolant(that I can see, anyways). I've heard that driving short distances can cause condensation to build-up, and I do have a fairly short commute to work(10 mils one-way), but the engine always reaches operating temperature.
I have heard of head gasket problems on the 5.4L. I've also heard that a clogged PCV valve can cause condensation. Thankfully, I did buy an extended warranty with the truck, so the repair won't put me in the poorhouse.
Now, I'm wondering what to do. Should I take it to the shop immediately, or keep driving it while keeping an eye on the condensation?
My truck is a '99 with the 5.4L, and 74,500 miles.
Old 12-15-2006, 02:56 PM
NASA_Hokie NASA_Hokie is offline
NASA_Hokie is starting off with a positive reputation.
10 miles on a 5.4 is a short trip, especially during the winter. Take it out on the highway for a while then check it.
Just because the temperature gauge says the water is warm, it doesn't mean that the engine is warm.
Redf150XLT Redf150XLT is offline
Redf150XLT is starting off with a positive reputation.
I have heard that a certain amount of condensation on the cap is quite normal (especially with relatively short drives). If you found a milky substance on the dip stick or in the oil itself, that would be a different story.
Old 12-15-2006, 03:25 PM
Thanks for the responses. I'll keep checking the dipstick, and I'll check it after the next highway run I have. I might even look in to having an oil sample analyzed.
Old 12-15-2006, 03:54 PM
ranger88a ranger88a is offline
ranger88a is starting off with a positive reputation.
It,s normal in colder weather for such short trips!
Old 12-22-2006, 10:11 PM
stein78 stein78 is offline
stein78 is starting off with a positive reputation.
I get the milky crud under the oil cap in the winter with my short trips to work, but it's gone in the summer months. I just change the oil more frequently in the winter.
Old 12-23-2006, 01:21 PM
backdraft529 backdraft529 is offline
backdraft529 is starting off with a positive reputation.
i have a 97 ford f-150, 4.2 V6 and i have the same problem. in the winter i have the milky substance on the cap but not on the stick. then in the summertime its gone.
Old 12-24-2006, 10:07 AM
F-250 diesel F-250 diesel is offline
F-250 diesel is starting off with a positive reputation.
i checked it after driving 3 hours on the thruway and its clean. I just checked it after a week of town driving and its back....just a little though, i just wipe it clean
Old 12-24-2006, 01:21 PM
afirecat afirecat is offline
afirecat is starting off with a positive reputation.
Use synthetic problem gone!!!
Old 12-24-2006, 06:30 PM
not true.....i switched to AMSOIL and i still get it a little
Old 12-25-2006, 09:31 PM
Well, I took a pretty good drive a couple of days ago, checked the oil cap, still had crud on it. Checked the dipstick, nothing but clean oil. As I remember, I don't think it ever had that stuff on the dipstick. I'm not all that worried about it now, based on what I'm hearing on here. I'll just keep an eye on it!
Old 12-26-2006, 07:24 AM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
The crud is condensation in the crankcase. The pcv valve is supposed to remove it, but if you only take short trips, it hasnt got a chance to do its job. Chrysler v8s have the same issue going on. They've issued a baffle to put in to the oil filler tube to keep the crud from reaching the cap. Just make sure the pcv valve is functioning and the tube isnt stopped up.
Old 12-26-2006, 01:52 PM
Actually It verry common, I used to work in a shop and change oil and 90% of them do this in the winter months, short trips dont help it doesnt allow the oil to heat up enough and get the condensation out, it will usually only form on the cap, DONT WORRY!!!, change your oil a couple of times in the winter if your concerned.
Old 12-27-2006, 07:58 AM
Quote:
Funny that you mention that. My dad had a '94 Dodge Ram with a 318, and he had the same problem. The dipstick even rusted at one point! He kept having it looked at and tested, but there was never a leaky head gasket the whole 118,000 miles he drove it. Not bad for a Dodge, eh?
Old 01-31-2007, 06:51 PM
Karma Karma is offline
Karma is starting off with a positive reputation.
I had the same milky oil cap on my truck, but the dip stick looked normal. I have a very short drive to work, in a very damp climate. I wiped it off and went for a 3 hour drive on the highway, and it hasn't returned since. These forums rock! Thanks.
Gunk on oil filler cap..gasket issue? graduate 1987 - 1996 F150 & Larger F-Series Trucks 2 03-01-2015 05:09 AM
1981 F-100 300ci Inline 6 HELP PLEASE? Va_Cleaner 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 02-17-2012 10:04 AM
Creamy colored foam on oil filler cap and in dip-stick tube. Big Red 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 12-03-2011 12:43 PM
70 Ranger XLT Factory Air Question 70_RangerXLT 1967 - 1972 F-100 & Larger F-Series Trucks 4 07-21-2010 02:33 PM
The Genedad 2 appears to be a success! ernesteugene 1999 - 2003 7.3L Power Stroke Diesel 29 10-11-2007 11:26 AM
Tags
2002, 42, 97, cap, commute, condensation, crud, diesel, dipstick, engine, f150, filler, ford, milky, moisture, muffler, oil, short, temp, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
