Home acid dipping solutions??
Tom Brownell's book, "How to Restore your Ford Pickup 1946-1967" has several pages describing home made acid dip using a barrel, water and lye with heat applied to the solution to speed up the process. I have never tried it, because how do you get rid of 55 gallons of dangerous toxic chemicals?
[font size="1" color="#FF0000"]LAST EDITED ON 07-Sep-01 AT 11:50 PM (EST)[/font][p]I am looking to prepare various small suspension parts on my 57' f-100, Hangers, u-bolts, etc. I live Washington, lots of moisture, lots or suface rust. I was looking at making a smaller acid dip process, not quite the 55 gallon amount.
Consider trying electrolytic rust removal. Do a web search for "electrolytic rust removal" and you should find an article by a fellow, I think his name is Kimsey, describing the process. I have been using the process for awhile now on antique farm tractor parts with great success. I have the same rust problem you have, I am located near Enumclaw, WA. The best part is that there is little or no concern about waste disposal, as you end up with a solution of really dirty, rusty water and some washing soda. I found washing soda in my local Fred Meyer store.
on
Use liquid molasses, available for about $15 for 5 gal at feed and grain stores.
Use a 4:1 ratio; 4 parts water to 1 part molasses.
Immerse the part and cover. Check weekly; in moderate climates it takes about 3 weeks to completely derust a flathead block, particularly the water passages come out scale free.
All grease must be removed first, and also remove paint if you want a uniform finish.
Gets pretty ripe so store well away from the house!
In hot climates it works a lot faster and if left too long makes a real mess.
Reusable several times, and then pour over the lawn, great fertilizer.
Remove the part and rinse off the gunk with a hose, some use a mild soap solution and then clean water.
Protect the part from new rust by your favorite method.
If you go to the following site, you'll see where an Australian fellow used molasses to dip his entire body! Check out use of a child's plastic wading pool!
http://www.users.bigpond.com/glenn_percy/hotrod.htm
Find the link for stripping the body.
I personally use Blue Lightning derusting solution.
Tim in Burien, WA
'56 F100 Project in Process
Featured on my website: www.users.qwest.net/~tkbowman
Tim in Burien, WA
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
Tim:
You mind telling us a little more about the "Blue Lightning"? I don't recall ever hearing that brand name. TIA.
[/FONT]
https://www.ford-trucks.com/dcforum/User_files/StockMan/flag.gif
[FONT COLOR="#ff0000" SIZE="+2" FACE="Signature"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="3" FACE="arial"]
[LINK:www.ford-trucks.net/users/stockman|Stockman's Club FTE Site]
[LINK:www.67fordtruck.com|1967 F-Series Registry ( www.67fordtruck.com )]
Tim:
[/FONT]
