'60 292 Smokes badly!!!
My 1960 F-100, 292 Y block is smoking real bad, and I'm getting a frothy oil from the crossover pipe flanges. Any ideas?, valve spring, valve seals or guides??? I love this site, I have learned so much about restoring my baby. Also, any ideas on places to get leaf springs and front turn signal lenses? Thanks so much. Gary
If it started all of a sudden, a possible cause is a clogged oil drain hole at the back of one or both heads. Rather than drain, the oil pools up and then gets sucked down the rear intake valves. Just pull the valve covers and see if any pooled oil exists. Actually a common problem on well worn Ys. Easily cleared with a stiff wire. If not clogged drain holes might be something more serious like worn rings, eroded umbrella seals on the valve stems, or badly worn valve guides. Good Luck
Good luck on your smoking problem. As far as lenses try
John's F-Fun hundreds: www.f100.com/5766Shop/index.htm
Mac's antique auto Parts: www.macsautoparts.com/
I'm sure there are lots of others but these are ones I have done business with.
Bob
1960 F-100
1995 F-150
Bob
1960 F-100
1995 F-150
