2001 F350 Super Duty Drivers Side Lean
I have an 2001 F350 Super Duty 4x4 ext. cab with the 7.3 PSD. I have a problem where the drivers side front is leaning down 3/4 of an inch lower than the pass. side. Everything seems to check out, and nothing appears broken. Anyone ever heard of a cheap and easy fix for this? Thanks, clego
Your truck has a natural rake built into it. The back being higher than the front from the factory. Look at the back spring packs. Count every spring and double check to make sure that you do not have one busted. That would contribute to your lean. One other thing, if you havent had the truck from new the prev. owner may have made a quick fix up front by installing a heavier or weaker spring on one side.
I'm just trying to eliminate any other possibilities.
Ford has a TSB for it. Check it out here, I cured mine using parts from their TSB:
https://www.ford-trucks.com/forums/4...ml#post3514353
Sorry to dredge this one up for a first post but im getting desperate.
Im currently trying to resolve the same issue. I have a 03 SD with a 7.3. I have a horrible lean towards the driver side of the truck. Measured at 1 1/2 inchesat the front left . I thought it was a sagging front spring so I replaced with a rough country leveling kit. The kit comes with new spring packs. Put the kit on and I still have the lean. I havent measured the rear yet.
Would a bad rear spring cause the front to sag as well?
