5-speed OD manual trans to 390 FE possible?
The 4-speed manual trans in my pu is jumping out of third gear,and it's getting to be time to replace or update it. It is a 1971 Ford F-250 4X4 with a 390 FE engine. What do I need to put a more modern 5-speed manual overdrive transmission in my truck? Is it ever possible?
To my knowledge...it is NOT possible to install a ZF (FORD) 5 spd to your FE engine. The bellhousing is part of the tranny case...and cannot be modified.
However...there are kits available to install a NP4500 (Dodge version) 5 spd tranny on the FE engine. This is a very popular upgrade!
Do a search in the FE forum here at FTE...and I am sure you will find it. I would give you the FTE member who did the conversion...but I cannot remember. Sorry...
biz
biz
5-speed and FE
Originally Posted by 47,52,69,92
check out advance adapters they have a two speed spliter that goes infront of your trans and is od/1:1 or underdrive/1:1 so that would be like having a duplex trans like an old mack truck except it will shift easy and at speed without skill!
Originally Posted by knuckleharley
Thanks! I'll try to do a search.
https://www.ford-trucks.com/forums/3...390-roars.html
Hope this helps...Good luck!
biz
NV4500 to FE
Originally Posted by biz4two
Went looking for an old thread...and here it is. Can you tell I LOVE the 390FE motor!!!
biz
biz
Originally Posted by Dave Severson
Oops, til you said cheap, I was going to say take a look at the Tremec TKO trannies, they make them up to a 600 ft. lb. torque rating.... Just kind of spendy.....
5-speed overdrive for 390
Originally Posted by 51dueller
Just find a 5spd out of a F-600-800. The O/D versions are a little harder to find than the direct ones though.
Originally Posted by jdbanks
Anyone know what Dodge models and years would have the NV4500 in them to look for in the scrap yard? Seems like I could find one much cheaper there.
Here is some GREAT reading:
http://www.nv4500.com/newsdesk_index.php/newsPath/12
http://www.high-impact.net/transmiss...sionsFordTruck
Hope this helps...
biz
68Ford4Life
23
04-22-2017 06:52 PM
JTGreenMachine
03-16-2011 01:19 AM
Cobra Highboy
01-10-2010 08:01 PM
ford4btrorwrse
12-03-2007 06:18 PM
knuckleharley
12-20-2006 08:04 AM
