Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 12-17-2006, 09:35 AM
captchas's Avatar
captchas captchas is offline
captchas has a very good reputation on FTE. captchas has a very good reputation on FTE. captchas has a very good reputation on FTE.
sorry guys
but the above user's back me up here. the strain placed on the park pall which is really only to back up the parking brake. gets jambed into a 6 inch round gear with some very course deep teeth to hold a moveing pall that is 3/8ths of inch thick and about 2 &1/2 inches long to hold all the weight of the truck . that is what jambs.
  #17 (permalink)
Old 12-17-2006, 12:37 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.
Yes it does a lot for a small device, but I think the orginal OP has a problem with the brake switch or the shift lock actuator since it has happened several times on level surface. Even with a pawl locked down you can pull it out 99.999 percent of the time. The newer trucks have a whole different shift lock and columb assembly and they use a 5 or 6 pin brake lamp switch too. You can have brake lights working fine but the shift lock circuit be screwed up. Ive replace quite a few of these newer style brake lamp switches for various faults due to it having so many separate circuits served off one switch.
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
IF IT AINT BROKE DONT FIX IT!!
My Missing Michelle
  #18 (permalink)
Old 12-17-2006, 12:39 PM
HYDAFL HYDAFL is offline
HYDAFL is starting off with a positive reputation.
I dont think this has any thing to do with the tranny. I believe it is in the column. if i ever find out i will let you guys know. .thanks for all the tips
  #19 (permalink)
Old 12-17-2006, 04:23 PM
captchas's Avatar
no it's not the colume it's one of the above any thing from a fuse, stop switch to a jambed pawl.
only time i saw a problem in the cloume a cast pot metial part had broken and the truck had to be towed in.
from your desription you had the pawl jambed in the gear on the tail shaft. just as a try it, next time this happens try rocking the truck just a little bit while moveing the lever. if it comes right out you know you need to set the parking brake.
  #20 (permalink)
Old 12-17-2006, 05:44 PM
I could understand if its the pawl jambed if i was parked on any sort of an incline.But both times were on smooth flat payvment. Which fuse are you guys talking about? For it to shift you have to depress the brake rite? Could it be there in the brake area?
  #21 (permalink)
Old 12-18-2006, 08:16 AM
captchas's Avatar
it's on the fuse box. sorry i don't remember the number to help you. yes i have had the pawls jamb on a flat also. just we have so many things that cause problems now that we never had to deal with before.
i would still get in the habit of setting the brake for my own safety.
  #22 (permalink)
Old 03-11-2007, 11:46 PM
ITDave's Avatar
ITDave ITDave is offline
ITDave is starting off with a positive reputation.
What ended up being the real problem / resolution to this? I have the problem now...
I had to take the console cover off per book instructions and depress the manual override to get it out of park. I would rather fix this my self if it is an easy fix as I cannot really afford to take it to the dealer right now. Please advise.
My brake lights work, however, I have seen that this can still be a fuse or a blown stop lamp circuit when this happens?
Thank you.
Dave Hobley
Dave@Hobley.com
253-486-9818
__________________
'99 F-150 XLT SuperCab 4.6L
K&N Air Filter
'04 F-150 Lariat SuperCrew 5.4 3.73 LS
Ford Gold Alarm / Remote
Retrax Roll Top Bed Cover - Lund Stainless Steel Bug Shield
Join Club FTE
  #23 (permalink)
Old 03-12-2007, 05:49 AM
If you have the floor shifter then you may have a bad shift lock actuator. Ive had to replace a bunch of them on the floor shift models. Most of them have had the opposite problem however, as they will NOT lock and the cruise stops working because it interferes with the deactivation circuit.
Since you have a multicircuit brake lamp switch you need to check each pin for 12V with the brake applied first. If one has a substantial voltage drop then you need to replace the switch first.
Ive also seen some of the floor shift lever assemblies get jammed up inside at the flap and you have to replace the whole lever assembly. There is a TSB on that for the Explorers which use a similar shifter. They are mostly plastic crap these days.
__________________
My Missing Michelle
  #24 (permalink)
Old 03-12-2007, 11:53 AM
ITDave's Avatar
Thanks for the information. Where exactly is that switch located? That is probably the problem.
At least, I would think that is likely the problem as when you push the manual override button, white button next to the shifter, it disengages and shifts out of park fine and all other gears shift fine using the button on the shifter.
Dave
__________________
K&N Air Filter
Join Club FTE
  #25 (permalink)
Old 03-12-2007, 01:06 PM
The switch is mounted on the the brake pedal assembly. It has a 5 or 6 pin connector plugged into it.
__________________
My Missing Michelle
  #26 (permalink)
Old 03-12-2007, 01:17 PM
ITDave's Avatar
Thanks, I looked at the brake pedal and didnt see that. Will look again tonight.
Thanks again!
Dave
__________________
K&N Air Filter
Join Club FTE
  #27 (permalink)
Old 03-12-2007, 01:27 PM
Here is a quick pic of mine. You see the yellow cap over the retainer clip and the black switch with a black (some are brown) connector.
__________________
My Missing Michelle
  #28 (permalink)
Old 03-12-2007, 10:45 PM
ITDave's Avatar
Thank you! Had just found that before getting on the internet this evening. That was very nice of you to take a picture! Thank you for that. That is some great resolution!
So, I pulled the plug out (was plugged in firmly), inspected the connector and pins, and then plugged it back in with no change.
Is there something under the yellow cap that I should be looking at?
Thanks again,
Dave
__________________
K&N Air Filter
Join Club FTE
  #29 (permalink)
Old 03-12-2007, 10:54 PM
ITDave's Avatar
Thanks again for the info. I just noticed the link about your beautiful daughter. I am so sorry to hear that! I hope and pray that she comes home soon, just walks right through your door. Best wishes to you and yours, our thoughts and prayers are with you!
Dave, Kimberly, Sierra and Jessica Hobley
__________________
K&N Air Filter
Join Club FTE
  #30 (permalink)
Old 03-12-2007, 10:56 PM
ITDave's Avatar
I was looking at that switch, and saw this post on one of my other postings; "Something I noticed was that even if your brake switch is activating the brake lights, it’s a different switch inside of it that’s running the shift interlock and it may not be functioning."
I am wondering how hard this is to replace?
Thanks,
Dave
Any idea what a fair price will be for the dealer to troubleshoot or replace that switch. I have already part of the legwork, checked all related and some other fuses, etc. Pulled the console cover off, etc.
Thanks again!
__________________
K&N Air Filter
Join Club FTE
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
