vacuum diagram for 351m
Okay
Please reply with:
DSO code
AC or non-AC
Axle ratio
Transmission type
although I do suspect this diagram applies to your truck.
I just need verification.
http://www.clubfte.com/users/mil1ion/7_72J_R11.jpg
Please reply with:
DSO code
AC or non-AC
Axle ratio
Transmission type
Does anyone have a vacuum line diagram for 1978 F250 351m? Ex took my truck apart and trying to get it running right again. Chilton manual doesn't cover all the lines. Have it all together now except running a lil rough, not sure if it is the lines hooked up wrong or carb adjustment. Have adjusted the carb the best I can get it and can tell a have maybe 1 or 2 lines hooked up wrong....sure could use some help from one of you guys out there. Please e-mail a diagram if you have one...Thanks.
Welcome to the site
I'll be happy to supply you with a diagram and probably an illustration.
However,
Maybe Re-read the previous posts and declare what your info is.
saying 1978 F250 351M is NOT enough info as per my previous replies.
Also, maybe start your own thread so an other person thread doesn't get confusing.
EDIT:
an auto trans will be diagram code 7-72-R11
manual trans will be 7-71-R10
However,
EDIT:
chizzy matt
07-07-2012 06:11 PM
craighardy
10-12-2010 06:17 PM
snow991025
10-08-2002 11:19 AM
