Steering box
Steering box
Thanks for your info,on the steering box assembly!!
I have a half an inch between the frame and the back of the pitman arm. Do you figure that is far enough?
The spline is almost through the pitman arm,around 3/4 of an inch.
I have been ordering parts from Fred Dixon of Missisauga,Do you recomend anyone else?
Steering box
That sounds about normal for distances.
Supply houses I've used and can recommend include Sacramento Vintage Ford, Bob Drake, Reds Headers, Patrick's, Obsolete Ford Parts, Mack Products, Mac's Antique Auto Parts, Hot Rod's Ford Trucks, Hot Rod & Custom Supply, etc.
I recently rebuilt the steering gearbox on my '48 F1. It made a world of difference over the 1/4 turn play I used to have
Good luck with yours,
Tim
Tim
Steering box
I have finally got my 51 Merc 1/2 ton running!!!!! 239 Flathead all stock, my question is 50 years ago these engines used leaded gasoline and now pretty hard to find unless 80/87 aviation fuel is available..what is everyone using?? A lead additive or a little 2 cycle oil or ???? Ted
on
Steering box
There are several flavors of flatheads out there and Im not sure about Canadian builds.
In the US 50 was the last year for hardened seats on intake and exhaust, 51 was a mix with some exhaust only and 52-3 did away with them entirely.
My 49 286 cube block in a 53 Victoria has about 45K miles on unleaded but I regularly add about 5 ounces of Mystery Oil to the gas.
I do the same to my 54 239 OHV in the F350.
Another thing that helps with long neglected engines is to run a quart of ATF down the carb to burn off deposits.
