5.4 Triton Power Upgrades - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 12-12-2006, 06:13 PM
3KIDDAD 3KIDDAD is offline
3KIDDAD is starting off with a positive reputation.
What are you guys using for reliable power enhancements on this engine?
Old 12-12-2006, 08:02 PM
davesexpedition davesexpedition is offline
davesexpedition is starting off with a positive reputation.
My current performance mods include K&N Intake w/ heatshield, flowmaster 40 series, and 75mm intake (soon to include the throttle body elbow being ported).
Those dont equal much at all I'm sure in the HP department, but they scored big in my SMILE department! I'll go the way of tuner/chip next, and when I'm making the big bucks next year... supercharging/N02
Old 12-12-2006, 08:08 PM
pronstar pronstar is offline
pronstar is starting off with a positive reputation.
ATI Procharger.
Old 12-12-2006, 10:07 PM
03GrnEBExpy 03GrnEBExpy is offline
03GrnEBExpy is starting off with a positive reputation.
If you have a 24v 5.4 check out the Whipple supercharger, it is a lot of money but has awesome power. They offered it for the 16v for a short time then quit.
Old 12-13-2006, 01:25 PM
04markIII's Avatar
04markIII 04markIII is offline
04markIII is starting off with a positive reputation.
Quote:
Originally Posted by pronstar
ATI Procharger.
just checked out their site. says install in only 8-10 hours. no prices though. submitted app for catalog. you do it yourself or professional install? drop in, ot doe i HAVE to change other stuff?
Old 12-13-2006, 01:45 PM
200cs 200cs is offline
200cs is starting off with a positive reputation.
do your homework.....We installed a whipple on the bosses Escalade. It was good for one pass and then the blower heated up the intake air so much that the ecu pulled all of the timing and the motor had less power than it had when it was n/a. The Whipple is not intercooled and that is not good. Look at all of the available ones out there, even Ford has one I have seen in Summit Racing. Good Luck.
Old 12-13-2006, 02:14 PM
Quote:
Me and a buddy did it over a weekend (two full days).
We took our time.
IMHO the best & most reliable install will be the Procharger kit...plus larger fuel injectors/fuel pump/custom tune (not part of the kit).
The Procharger kit comes with an FMU to increase fuel to the engine, but this is not incredibly reliable/accurate.
You'll make more power, and have better control of your air/fuel ratios, byt installing larger fuel injectors/fuel pump/custom tune.
But lots of guys are using just the Procharger kit with good results.
Old 12-13-2006, 02:16 PM
04markIII's Avatar
how much was your kit? trying to decide between a lightning swap and just a procharger as stated in your post above. also, i literally just had new spark plugs installed. will i have to swap them out for colder ones?
Old 12-13-2006, 02:33 PM
built79 built79 is offline
built79 is starting off with a positive reputation.
Hello everyone, new here because I just sold my 02' lightning and bought a 2000 5.4 4X4 expy-really like it so far.
Anyway, I used to work for ATI procharger and for what RPM the 5.4 motors like, the roots/screw blower will be much more practical. Also, the Expedition kit uses (4) small idler pulleys which tend to burn up often. Other problems are the P-1SC model superchargers all leak. The procharger will give great "peak" power figures but low end torque will not change much. The eaton is without a doubt the more reliable, usable blower.
Old 12-13-2006, 02:38 PM
04markIII's Avatar
ok, so now i just have to find a litning kit cheap!
Old 12-13-2006, 02:51 PM
04markIII's Avatar
Old 12-13-2006, 03:01 PM
The eaton blower would be my choice, but be careful. The harley/lightning motors have forged pistons. I'm not saying the expy 5.4 can't handle 8-10psi, just not as long as the lightning... Premium fuel and octane booster is recomended, and watch those spark plugs!
Old 12-13-2006, 03:10 PM
04markIII's Avatar
Quote:
arent they both eatons? pardon my newbieness! i just had new plugs installed at the dealership this past saturday, so i should be set. do i have to change to colder plugs?
Old 12-13-2006, 03:22 PM
Sorry, I was referring to the eaton vs. procharger(discussed earlier) and I wouldn't run anything colder than the stock lightning plug or you'll run into some fouling. The 5.4's of some years were known to eject sp plugs and adding a blower certainly won't help prevent that problem! Prof. tuning would also be recomended.
Old 12-13-2006, 03:24 PM
04markIII's Avatar
i plan on having it tuned by the tuner who tuned my xcal II. so, no real big difference between the harley vs lightning...just whichever has a better deal?
power steering swap details? rebocardo 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-26-2002 10:36 PM
Banks Power Pack redranger1 1999 to 2016 Super Duty 7 08-12-2002 09:02 PM
More power cmullens Excursion - King of SUVs 12 06-10-2002 09:11 AM
95 Power Stroke alanscott 1994.5 - 1997 7.3L Power Stroke Diesel 3 05-24-2001 11:53 PM
V-10 power differences- fishinbum 1999 to 2016 Super Duty 3 02-21-2001 09:00 AM
Tags
2006, 54, chip, f150, ford, gauges, headers, horsepower, hp, performance, power, procharger, triton, upgrades, whipple
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
