Electric fan options for Bronco
Hi, I would like to add a dual electric fan set-up, mainly to get a bit better access to the engine compartment. Are there any stock electric fans that can be relatively easily mounted onto the radiator for a 95 Bronco? We have u-pull-it yards where I could get a set (I'm assuming I'll need two) for likely around $50 instead of $400 from what I've seen. Also, if I go this route, could you recommend a relatively easy thermostatic control?
Thanks,
Biederboat
Thanks,
Biederboat
I wouldnt cheap out on the fans, since you are messing with a fundamental part of the cooling system. If you plan on using the truck for towing, then i definetly wouldnt cheap out. Plus by the time that you get around to getting the fans, mounting them, wiring it in, and getting a control box, you might just be close to the $400 range with the problem that it might not work as well as you had expected. If it was my truck, I wouldnt cheap out and potentially cause some major problems in the future.
biederboat
04-27-2005 11:19 PM
