Blinking Instrument Cluster Lights???!!
Old 12-11-2006, 10:25 PM
levirox's Avatar
levirox
levirox is offline
Angry Blinking Instrument Cluster Lights???!!
I am completely stumped. I have a 98 Ranger XLT with 4 Wheel Drive and high miles (probably similar to most of us on here with older Fords). The other day my instrument cluster lights went out all the way across the dash (except for the radio lights). At the same time, the tail lights and marker lights up front went out, and the turn signals now flash the instrument cluster lights. This is a major problem for me. I had hoped that the lighting problem was related to my other problems with the dome light and windshield wipers so I replaced the GEM module. The new/used GEM module fixed my wiper and dome light/door buzzer issues but did nothing for my lighting issues.
In doing the do-dilligence of searching the site before posting a question that has been asked a hundred times I found out that there are a lot of people that have had the same symptoms that I'm having but no real answers for any of there problems.
Below are the links to the threads that others have posted with similar symptoms. Any help would be greatly appreciated.
https://www.ford-trucks.com/forums/429417-instrument-cluster-running-lights-out.html?highlight=Flashing+Dash+Lights
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
https://www.ford-trucks.com/forums/427150-98-ranger-dash-lights.html?highlight=Flashing+Dash+Lights
<o></o>
<o></o>
https://www.ford-trucks.com/forums/420939-electrical-question.html?highlight=Flashing+Dash+Lights
<o></o>
https://www.ford-trucks.com/forums/232236-98-ranger-issues.html?highlight=Flashing+Dash+Lights
Old 12-11-2006, 11:42 PM
levirox's Avatar
levirox
levirox is offline
Finally I found in the repair manual that the fuse number I needed to check was actually in the power distribution box under the hood. Fuse number 11 was the culprit. Now I'll just have to wait till it blows again to see if I can trace it back from there, hopefully there isn't a bigger problem lurking somewhere.
Old 12-12-2006, 08:20 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
The instrument cluster lights blinking with the turnsignals sounds like a grounding problem. Check along the frame rail all the way to the rear and around the rear bumper. Stuff can get caught under the truck and damage the wiring, or someone could have modified the wiring for a trailer, and now there is a problem with corrosion. Most of the other wiring related to these circuits is protected fairly well. The only other problem spot is around the brake and clutch pedals if the wiring gets caught in the linkage.
websurfer
1997-2006 Expedition & Navigator
19
02-21-2024 06:19 PM
AZRogala
Computer Chips & Tuners
17
12-11-2015 04:30 PM
nailerdog
1999 to 2016 Super Duty
02-23-2011 07:37 PM
michael101
Escape & Escape Hybrid
05-16-2010 03:56 PM
PhilfromFlorida
30
04-02-2008 03:50 PM
Quick Reply: Blinking Instrument Cluster Lights???!!
