Can a T18 replace a NP435?
As mentioned in my other post, I have two T18's for a Jeep project.
In another thread, I mentioned how my NP435 needs rebuilt.
Would the T18 bolt in to replace the NP435?
Are the spline counts and lengths usable with the NP205?
EDIT: I found this on a website with info for swapping Ford trannie's to Jeeps.
T18 and NP435 both have:
1 & 1/16th 10 spline inputs.
Both pilot tips are 0.668".
Input shaft stickout, 6 1/2".
Front bearing flange, 4.85".
Tube is 1.43".
What would keep this from swapping over?
Thanks,
Blair
Tube is 1.43".
Thanks,
Blair
I am not sure if the over all length between the two is the same or not but if you have both then whay can't you just measure them yourself? Now if you are asking about a 4x2 trans accepting a transfer case then no. The trans has to have an output shaft for a 4x4 set up and then the correct adapter between the trans and case. The 435 adapter is different than the T18 adapter or it is on the tranny side but the transfer case share the same mounting pattern and the output shaft should be 31 spline.
on
Bell housing bolt spacing is different also between the T-18 and the 435 as I remember from the old Advance Adapters catalog I have, so a new one is in order for it. But I believe that Ford used the same TC adapters with the same spline count and bolt spacing between different tranny's.
I've got a small block hyd bell housing from a 300 6cly that had a t18 trans and it hs the same bolt pattern as my 435 from a 78 bronco. I just measured this for the buyer of the bell housing.
I agree the transfer case end of the adapter will be the same but I am not sure about the trans end of it.
Dave 64
06-18-2016 05:12 PM
Slow
11-19-2007 11:27 PM
90Bronc
02-27-2002 05:01 PM
onebad40willys
01-23-2002 08:57 PM
