302 CARBURETOR Cold Air Intake - Ford Truck Enthusiasts Forums
Old 12-10-2006, 10:28 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
I have a 1985 F-150 with a 302 2 barrel carb soon to be swapped for a Holley 4 barrel. The stock cold air intake (Air cleaner, snorkel, and air intake tube) is long gone. I would like to get another cold air intake, but have had no luck in finding one for carbed motors. All I can find is the open element air cleaners. Is there a reson why Summit, jeg's, etc. do not carry these? Which leads me to wonder, is there really any advantage to running a cold air intake versus an open element air cleaner for carbed motors?
Old 12-11-2006, 12:58 PM
blackout150's Avatar
blackout150 blackout150 is offline
blackout150 is starting off with a positive reputation.
old style air cleaners with the snorkel are more restrictive, and an open element provided more airflow. However, it was warm air from the engine compartment. 85 mustang Gt's had a dual snorkel air cleaner which would provide more air at a lower temp if routed correctly, but would still be more restrictive than an open element cleaner. Your call at that point what you want to do.
Old 12-11-2006, 04:21 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Put an induction scoop on the hood.. reverse mounted like they did on the old '80's camaros/firebirds.
Where can I find an air cleaner housing? Nothing Special 1966 - 1977 Early Broncos 1 11-22-2015 05:21 AM
Air Cleaner for 351m 46Whizzer 1973 - 1979 F-100 & Larger F-Series Trucks 13 02-18-2015 10:25 PM
Hot Air Choke 2150 Motorcraft Rusty_S Fuel Injection, Carburetion & Fuel System 10 12-12-2012 03:24 PM
Cold Air Intake Setup? ken selvy 1973 - 1979 F-100 & Larger F-Series Trucks 24 05-22-2009 09:09 PM
Ford Mustang Air Cleaner/Dual Snorkle LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 04-28-2007 06:24 PM
Tags
1985, 302, 302ci, air, carburetor, cleaner, cold, diesel, dual, engine, ford, gt, intake, mustang, open, snorkel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
