Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-16-2001, 06:25 PM
darkman is starting off with a positive reputation.
Tire size, rear end, and motors
__________________
Restoring at the speed of a slow sick snail !
Charles in Pensacola
57 F100 adding Blown 312 auto
86 F150
92 F150 351W 4x4
97 F150 4.6L RIP December 14th, 2006
05 F150 5.4L Lariat
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-29-2001, 05:44 PM
1953Man is starting off with a positive reputation.
I am putting a 302 in my 1953 F100 and someone told me a 3.73 would work, but I am running 205/50/15 tires now. Is it gonna make a different with the tires when I put the 3.73 in?
  #3 (permalink)
Old 12-29-2001, 08:01 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
If you have the original rear, It should be approx 3.90 to 1, so 3.73 is not going to be a dramatic difference.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 01-02-2002, 08:01 AM
ranger pat's Avatar
ranger pat is starting off with a positive reputation.
Here is the formula I used.
MPH X Gear Ratio X 336 = RPM/Tire Diameter
Example:
70 MPH x 3.50 gear ratio x 336 = 87729/Tire Diameter
With a 27" tire diameter, this works out to 3048 RPM
You can adjust tire diameter and gear ratio to get the
RPM you want to cruise at. If you end up with an overdrive transmission, factor .67 or final drive ratio into the
formula: MPH x Gear Ratio X Final Drive Ratio X 336 = RPM/Tire Dia.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
