takes a long time to start
having an issue with my 96. the motor turns over fast but will not, for the life of me, catch and start. white smoke comes out the exhaust, so i know its getting fuel. i looked today, i have fuel in the valley, could it not be getting enough fuel? any ideas would be appreciated. i am at college and dont have the opportunity to put in a new pump, but i will be doing that well i get home.
This is an assumption on my part, but I'm guessing you have a '96, right? I have a '97 with an E4OD. There is an Inhibitor Switch in the Transmission Range sensor to prevent the vehicle from being started in gear.
Has any tranny work been lately? Maybe it's the Camshaft Position Sensor (CPS). When the CPS fails, the engine won't start.
i have an auto tranny. i think its the fuel pump and not the cps because the tach moves when i turn the key, it shows the engine turning over. can air get into the fuel lines if the fuel pump is leaking? i think thats my problem. when i go to change the fuel pump, is the pump from napa a good one? i think its a carter pump.
Jump the GP relay and I bet she fires right up!!!
Jump it with a screwdriver for 20-30 seconds. That warms up the GP's and then with the fuel that you are definitely getting(white smoke) and a little compression you're off to the races. Easy test. Only takes a minute and then you'll know. If you're getting white smoke then it isn't your CPS or a fuel delivery problem. It takes a bunch(the correct amount when unburnt) of fuel to get white smoke.
If ya got a volt meter just check and see if your getting voltage across the relay after you turn the key on. And no...I don't think it maters if the key is on when you jumper it with a screwdriver....one side should always be hot.
My truck wont start in the summer first time around if I don't wait for the gp's....
