removing oil filter on 03 4.6 Crew
O.K. guys
Just picked up my new-to-me 03 4.6L 4x4 Super crew.
How are you supposed to get to the oil filter?????
On my 97 4.6 they remotely positioned the filter to the front bumper, This one is on the block directly above the 4x4 axle.
Also I am listing a topper for the crew on Ebay tonight, don't like it on the truck.
Thanks
Reamer
Thanks
Reamer
I own a 2 wd and I lean over the front of the truck and loosen it from the top with a regular filter wrench, then lay in front of the truck a remove it with my hand. Sounds like to oil filter on my Bronco, you have to remove it from the top also. I usually sit on the fender and try to get the filter wrench in the tight space to loosen it, then throw it on ground from top or pull it up out of there.
reamer
2004 - 2008 F150
05-04-2011 09:20 AM
