Replacing/Modifying AOD Tailshaft Governor - Ford Truck Enthusiasts Forums
Old 12-10-2006, 12:54 AM
Craigwell's Avatar
Craigwell Craigwell is offline
Craigwell is starting off with a positive reputation.
Tranny in question came from a van with 3.55 or 3.73 (90 E250 that I never saw, so not quite sure) but I am running with a vehicle that currently uses 4.10 gearing in the diffs.
I have been told to 'add weights' to the governor. Is this something I can do myself? Ford parts still available? Should i just try to find a 4.10 governor??
Then I am curious if I should re-visit TV Cable adjustment when governor is changed/modified.
Any insight is appreciated
Old 02-14-2007, 09:06 AM
BikerDude BikerDude is offline
BikerDude is starting off with a positive reputation.
I'm running an AOD and have never heard of changing anything associated with the governor when changing gears. Go to www.TransGo.com or www.baumannengineering.com and see what they have to say about the AOD. I am putting a TransGo shift kit in mine right now to help it shift better and live longer.
Old 02-14-2007, 06:53 PM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
An AOD governor is an AOD governor.
There is no difference as far as gearing is concerned.
The biggest problem lies with the cable adjustement.
It is critical and a poor adjustement can smoke an AOD transmission in a few miles.
4k+ RPM... What do we worry about? Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 24 01-02-2016 01:54 PM
Vacuum in HG? martyanderson10 Large Truck 14 04-12-2015 11:43 PM
ford c4 governor spring bbf150 Clutch, Transmission, Differential, Axle & Transfer Case 17 06-15-2013 01:55 PM
international truck air brake problems. RRranch Large Truck 6 12-28-2009 01:08 AM
Governor 2001 Ranger Tattoo626 Ranger & B-Series 60 08-20-2006 03:10 PM
Tags
4x4, adjustment, aod, ford, governor, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
