12 volt wiper motor for 55 f100
good news & bad news! I found a replacement Ford 12 V. motor for my 1955 truck at a swap meet. FOMOCO #CITB 175?4-J & American Bosch #
WWC 12J 2590. but I can't tell you what the motor came from. The motor bolted directly to the old mounting plate. I had to swap the rotating arm from the old motor but the shaft was the same. Motor is 12 V.,2 speed & has the built-in stop when you turn it off. Good Luck!
