Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > New York Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New York Chapter Join Chapter, Leader: tiny1
  #1 (permalink)
Old 12-09-2006, 02:53 PM
xcquad466 xcquad466 is offline
Garage is empty, add now
xcquad466 is starting off with a positive reputation.
bad vibration
hey guys I'll probably go the the GTG once I figure out a bad vibration. its a 97 F250LD 5.4L. When I'm on the gas from a stop it will vibrate real bad and once I get off of the gas I can still feel it but not as bad. Its driving me nuts. Also when I turn a corner I hear a click in the rear end, and it acts like it the tires are fighting each other when I take a 90* corner. Any help would be appriciated.
  #2 (permalink)
Old 12-09-2006, 04:39 PM
fast frank 66 fast frank 66 is offline
fast frank 66 is starting off with a positive reputation.
sounds like the ring and pinion are getting chewed up. i had this happen in my truck.
  #3 (permalink)
Old 12-10-2006, 08:18 AM
I put the rear up on jacks and started it up, then put it in gear. I can watch the driveshaft wobble back and forth..it almost looks out of round. what would cause this
  #4 (permalink)
Old 12-10-2006, 10:43 AM
Jdenninger's Avatar
Jdenninger Jdenninger is offline
Jdenninger is starting off with a positive reputation.
try replacing the u joints. they are probably worn. with the truck on the ground, is there any excess play in the drive shaft if you try to turn it by hand with no load on it? it may help to also get the driveshaft rebalanced
__________________
Jeffrey
'79 Bronco Ranger XLT Trailer Special 5.8M -SOLD!!!
'87 Suzuki Samurai JX - stolen by ex wife!
NY Chapter Member
  #5 (permalink)
Old 12-10-2006, 10:48 AM
Ronin007's Avatar
Ronin007 Ronin007 is offline
Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.
Does your drive shaft have a lot of play in it when you try to turn it by hand? Are your universals all good and lubed? It could be just bad universals causing your problems. Is there lube leaking out of either your transfer case or rear pinion? I would check your diff fluid to see if there is metal shavings in it.
Report back as to what you find. Your truck is a 4x4 right?
__________________
Darren
1999 F-350 Super Duty XLT 4x4 V10 extended cab
  #6 (permalink)
Old 12-10-2006, 03:56 PM
ya the truck is 4x4.. I found the culprit. bad rear u-joint.. but I noticed something else.. when the truck is up on the jacks and its in park I can rotate the tires pretty far until it stops. I can do this in both directions. could it be the clutch packs going???
  #7 (permalink)
Old 12-10-2006, 08:30 PM
Ronin007's Avatar
Check your rear diff fluid and see if there is metal in there. If so, it is possible.
__________________
Darren
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
