Intake Reccomendations
I am in the process of converting my '85 2 barrel carb for a Holley 570cfm 4 barrel carb (and Duraspark II ignition conversion) and I need a good all-around intake for a daily driver truck. I was looking at a Weiand stock type intake and an Edelbrock performer intake, but I also have seen some Holley intakes. Would I be better off matching the Holley carb to a Holley intake? Any suggestions would be welcome!
I"ve had good luck with the edleborock doing the same type of mod on an 83 351 good allaround performance and drivability. If you'er puting it on a truck with an automatic remember to get a carb with ford kickdown linkage and you may have to lengthen your kick down rod or find one for a 360/390 with a c6 as this is a litle longer and work well.
jonny.redneck
04-23-2014 04:43 PM
LARIAT 85
05-21-2008 04:17 PM
LARIAT 85
12-11-2006 03:21 PM
1965_ford_mustang
05-16-2002 09:30 AM
