vin tag for diff
Originally Posted by gab712
Can anyone id this tag on my highboy. It is a dana 60 i the rear and the tag reads:
4 10 D61A GEB should be D6TA...4:10-1 ratio
603717-11
Front is a dana 44:
603783-1
4 09 D6TA AAE 4:09-1 ratio
Thanks
603717-11
Front is a dana 44:
603783-1
Thanks
Axles are 1976 production
D=70's
6=1976
T=truck
GEB/AAE=engineering number
No need for quote.
GEB = engineering number ?
I don't think so in this case
4 10 D61A GEB = axle ratio and date codes
603717-11 = [/b]Bill of Material ID Number[/b]
All Dana 60 differentials are also marked with a date code which are found on both housing, inboard of the BoM number, and on the side of the cylindrical part of the differential. Formatted "MM DD Y", the date code always represents the year as a single digit, except on differentials which can be two digits. Housing date codes are followed by a letter (A, B, or C) which may indicate the work shift or factory line. Some differential stampings also show this letter suffix. Zeros are not used in month and day codes. Wide variation in spacing of the components of the date code is seen, and it is not unheard of to see two date codes stamped into a housing, one above the other. These two date codes are usually within a few weeks of one another.
Maybe Check out this page.
http://www.lightruck.com/axle_parts_rings.asp
Faithful Old Road Dog
04-16-2004 11:12 PM
scott9320
10-24-2002 08:19 PM
