vin tag for diff - Ford Truck Enthusiasts Forums
vin tag for diff
Old 12-09-2006, 12:45 PM
gab712 gab712 is offline
gab712 is starting off with a positive reputation.
vin tag for diff
Can anyone id this tag on my highboy. It is a dana 60 i the rear and the tag reads:
4 10 D61A GEB
603717-11
Front is a dana 44:
603783-1
4 09 D6TA AAE
Thanks
Old 12-09-2006, 12:50 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
4 10 D61A GEB should be D6TA...4:10-1 ratio
603717-11
Front is a dana 44:
603783-1
4 09 D6TA AAE 4:09-1 ratio
Thanks
^^Answers above ^^
Axles are 1976 production
D=70's
6=1976
T=truck
GEB/AAE=engineering number
Old 12-09-2006, 04:29 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
No need for quote.
GEB = engineering number ?
I don't think so in this case
4 10 D61A GEB = axle ratio and date codes
603717-11 = [/b]Bill of Material ID Number[/b]
All Dana 60 differentials are also marked with a date code which are found on both housing, inboard of the BoM number, and on the side of the cylindrical part of the differential. Formatted "MM DD Y", the date code always represents the year as a single digit, except on differentials which can be two digits. Housing date codes are followed by a letter (A, B, or C) which may indicate the work shift or factory line. Some differential stampings also show this letter suffix. Zeros are not used in month and day codes. Wide variation in spacing of the components of the date code is seen, and it is not unheard of to see two date codes stamped into a housing, one above the other. These two date codes are usually within a few weeks of one another.
Maybe Check out this page.
http://www.lightruck.com/axle_parts_rings.asp
68 f250 rear axle door tag code svemike 1967 - 1972 F-100 & Larger F-Series Trucks 10 05-11-2015 03:38 AM
Dana 44 rjbuningsr 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-12-2014 05:19 PM
Axle tags Stallion 429 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-17-2014 08:53 PM
axle tag ID cblood 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-04-2010 12:39 PM
79 f-350 front axles highrideford 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-05-2007 12:17 PM
Tags
09, 11, 60, 603717, 6037831, aae, axle, d61a, d6ta, dana, ford, geb, read, tag, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
