Site Servers
I have seen the same thing happen after a power outage from an ice storm. Everyones heat was wanting to come on at the same time and the circuit couldn't handle it. The power company blocked out sections and brought them back on line in smaller bits, took a couple hours longer that way, but they were all back on. The curcuit couldn't handle the surge, sounds like what was going on at FTE server center.
John
John
Originally Posted by Torque1st
Sounds like you need UPS units even in the server center.
Ken, I've done the *exact* same thing before. I am real familiar with that sinking feeling you had when all the little green lights in that cabinet went out at the exact same time - and probably a few of the curse words too.
on
Concerning Andy's comments.... how true!
At one point we installed a UPS in our rackspace even though the facility had a generator --- because a generator doesn't cover you in all cases. Sadly, as our use of rackspace increased it became harder to justify paying for an extra 3U of space for the number of UPS's needed to cover all the systems.
I know the server center has an UPS, but in this case an UPS may be needed at the server like Ken had before. Unfortunately space is very expensive.
I too have seen those little lights go out at the same time in a rack of equipment. It usually didn't happen too often to me since I checked all of the equipment draw before I plugged anything in and fired it up. Back in the old days tho some equipment got modified without updating rating tags. -OOOPS! Where I was working there were life safety issues involved and a computer going down could mean someone could die. I really sweated the monthly generator and UPS unit tests for several reasons. Pulling those big disconnect handles willingly and listening to the howls, generator startup, and transfer contactor banging was intense. If something went wrong that whole power room might go up with me along with it. Plasma burns are a bad thing.
