Serial Number Plate on a 56 F100
[updated:LAST EDITED ON 21-Jan-02 AT 07:28 PM (EST)]Patman56,
For a 1956, you should be able to find the serial number (or VIN) in two places:
1. On a metal tag riveted to the cab between the two hinges on the driver side door.
2. Stamped on the top of the right side frame rail between the cab and the front axle as 286merc indicated.
In case you need the decode info I've reposted it below. Good luck with your find.
Earl.
*tsseypnnnnn*
where the different fields are
t ss e y p nnnnn
From my 1956 Ford shop manual and other sources these letter fields translate to:
t - Truck Type
B = school bus
C = cab forward
F = standard
P = parcel delivery
T = ????
ss - Truck Series
10 = 100 series
25 = 250 series
35 = 350 series
50 = 500 series
60 = 600 series
70 = 700 series
75 = 750 series
80 = 800 series
90 = 900 series
e - Engine Code
D = 223 CID 6-cylinder
V = 272 CID 2 barrel 8-cylinder light duty
Z = 272 CID 2 barrel 8-cylinder heavy duty
R = 272 CID 4 barrel 8-cylinder heavy duty
J = 302 CID 2 barrel 8-cylinder
A = 302 CID 4 barrel 8-cylinder
K = 332 CID 2 barrel 8-cylinder
S = 332 CID 4 barrel 8-cylinder
y - Model Year Code
3 = 1953
4 = 1954
5 = 1955
6 = 1956
p - Paint Code
A = Raven Black
B = Nocturne Blue (dark blue)
D = Diamond Blue (light blue)
E = Colonial White (two-tone cab only)
G = Meadowmist Green (light green)
H = Platinum Gray
M = Goldenglow Yellow
R = Torch Red
U = Meadow Green
S = Special
nnnnn - Production Unit Number
Earl.
*tsseypnnnnn*
t ss e y p nnnnn
t - Truck Type
B = school bus
C = cab forward
F = standard
P = parcel delivery
T = ????
ss - Truck Series
10 = 100 series
25 = 250 series
35 = 350 series
50 = 500 series
60 = 600 series
70 = 700 series
75 = 750 series
80 = 800 series
90 = 900 series
e - Engine Code
y - Model Year Code
3 = 1953
4 = 1954
5 = 1955
6 = 1956
p - Paint Code
A = Raven Black
H = Platinum Gray
R = Torch Red
U = Meadow Green
S = Special
brig 56
01-27-2011 06:51 PM
ssj7kids
07-04-2007 07:02 AM
60f100trk
07-01-2001 06:18 PM
