1960 Rebuilt Steering Box - Ford Truck Enthusiasts Forums
Old 10-15-2001, 05:08 PM
truckzilla truckzilla is offline
truckzilla is starting off with a positive reputation.
Does anyone know where I can get a steering box rebuilt. I can get a used one but no one seems to have rebuilts. Tried a few on-line stores and Napa and the answer is the same - can't get it for a 60. Any suggestions??
Old 10-15-2001, 05:26 PM
50yellowbeast 50yellowbeast is offline
50yellowbeast is starting off with a positive reputation.
[font size="1" color="#FF0000"]LAST EDITED ON 15-Oct-01 AT 06:28 PM (EST)[/font][p]You got lucky as I was reading this post I was looking through my Sacramento Vintage Ford catalog. They do sell them rebuilt as Exchange only.. but they are a little pricy at $450.00 for your truck the part number would be # 7177. Goto their website at www.vintageford.com for contact info. Someone out there may be able to find it cheaper for ya.. But they have it.
49 Ford F-1 on 73 Ford F-250 3/4 ton 360/435/205 4 wheel drive chasis.
Old 10-15-2001, 06:52 PM
YEEEEOOOW!!! But at least its there. Its a 20 minute drive so I'll go check it out. But I bet there is another answer. Thanks for the tip.
Old 10-17-2001, 10:04 AM
imaknucklebuster imaknucklebuster is offline
imaknucklebuster is starting off with a positive reputation.
Pick up the latest issue of Hemmings. In the Ford truck section you will find a company called LARES. I think that they are in Michigan. I think that they would do it for around $250. Good Luck.
Old 10-22-2001, 11:04 AM
hirschi hirschi is offline
hirschi is starting off with a positive reputation.
If you want it cheaper... Mac's sells the parts for around $150.
Then just go get the old worm gear pressed off and the new pressed on. The bearing preload is nothing to worry about. They'll be able to instruct. Did it to mine and it works great.
I did'nt have to worry about the bushings.
Old 10-22-2001, 05:08 PM
Cool. Thanx for the info
Old 01-23-2002, 07:29 AM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
Old 01-24-2002, 12:21 AM
badreception badreception is offline
badreception is starting off with a positive reputation.
Hi,
have you tried Dennis Carpenter?
I think they are cheaper...
I also own a 60 truck up north in Seattle. Do you know of any good places for body parts (fenders etc.)? Up here everything's a'rustin away.
Cornelius
Old 01-24-2002, 03:41 PM
Try A1 Truck Salvage in Yuba City. He has 2 or 3 60's sitting there.
rfoote@syix.com
Old 01-24-2002, 04:58 PM
darkhorse54 darkhorse54 is offline
darkhorse54 is starting off with a positive reputation.
Have you thought about putting power steering on it instead?
Tags
1960, box, f100, rebuilt, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
