IP Adjustment. How much is too much?
I have just completed "turning up" the fuel delivery on my IP. I am now up to 2.5 flats from when it was stock NA. I increased 1.5 flats upon initial installation of Banks turbo. Now I have increased 1 flat. I know I need to watch my pyrometer but usually just "letting off" on the pedal cures high EGT's I don't want to "flood" the cylinders with TOO much fuel. Anyone got any suggestions? PS I haven't driven it since the last increase. Sitting in the driveway if I "punch it" I get a puff of black smoke but that clears up immediately. Thanks Tom
turbo
Originally Posted by Spectramac
I set one up to 3 flats once. A guy I know turned his in past 4. I've also heard of a guy that bottomed out the screw.
When you start seeing black smoke you have more fuel than you have air to burn the fuel.
With an increase in fuel delivery it is possible to gain MPG when you are running in rolling hills, a little more fuel lets you roll over the hill without dropping a gear.
But when you get in a hard long pull, more fuel means more power, but it also means your MPG is going down.
Originally Posted by Tom D
I suppose there is a fine line at which point you have gained max power and you use more fuel. I guess you can't have the best of both worlds. I want more power but I don't want to sacrifice the mileage. I suppose I can continue to increase the fuel delivery and pay close attention to the power,pyrometer,and fuel consumption.
Of course what's "just right" for one engine and IP may be all wrong for another. Seems to me that trial and error would be the only way to get it just right for your particular rig.
'Course I haven't tried getting mine "dialed in yet", been to busy getting it running decent. BUT I will be starting in on tweaking it VERY soon.....
IP Adjustment How much is too much
Originally Posted by bl311
Tom, Trying to squeeze more horses out of tired parts is tough. What is the age/condition of your IP and injectors? How many miles do you have on the truck. What mileage are you getting now?
Originally Posted by knapikmichael
what is the ip and my truck blows black and goes clear good or bad
Blowing black smoke is unburned diesel fuel and a sign that your IP is pushing more fuel than there is air available to burn it all. First thing to do is check/replace your air filter (if it is dirty) so the engine can get more air. If that isn't the problem, then you need to either look at making some intake mods to let more air in, or turning down the fuel delivery adjustment screw on your IP.
