noise coming from front end
Old 12-07-2006, 10:06 AM
F-250 diesel's Avatar
F-250 diesel
F-250 diesel is offline
Question noise coming from front end
when i go over a speed bump, i cant really explain the sound but it sounds like a rubbing sound, it only does it when the suspension goes up and down, thats why it only does it when you go over a speed bump. its on the front end that does and i go over the bumps slowly. its a 2002 supercab with only 39,000 miles on it and i bought it with 37,000 on it about a month ago. could this be bushings, ball joints, or could it need new shocks?
any help is appreciated
Old 12-07-2006, 08:59 PM
oscar_007's Avatar
oscar_007
oscar_007 is offline
I knew someone who had a noise comming from the front end every time they hit a bump. It ended up being the bolt breaking off that holds the sway bar down on one end. Check your sway bar at each end to be sure it is connected.
Old 12-07-2006, 11:17 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
That would be sway bar links.... How about you just have someone with some weight to them jump on u're bumper and you listen for the noise? Rock that truck like it was goin over the bump. Replication of enviroment is the key to finding the problem....
Old 12-08-2006, 10:08 AM
F-250 diesel
ok ill try that....someone said it could also be the bushings, but ill start with the sway bar
thanks guys
Old 12-08-2006, 10:14 AM
MrBSS's Avatar
MrBSS
MrBSS is offline
If you don't find anything broken or disconnected, you may just need to lubricate the bushings and grommets. Use silicone or other non-petroleum lubricant.
Old 12-08-2006, 10:49 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is online now
Received 2,739 Likes on 1,330 Posts
Yup...my truck also makes the noise, even when hitting certian bumps in the road. It's the sway bar ends hitting the links that are still on the A-arms. I need to go ahead and just take them off.
Old 12-08-2006, 12:52 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
Hey ATC, don't just take the sway bar links off, replace them. Disconnecting the anti-sway bar will be detrimental to the handling of your truck.
husker3in4
Escape & Escape Hybrid
10-23-2014 11:21 AM
SC_Dave
03-07-2014 07:26 PM
Steve Gosen
1997 - 2003 F150
08-29-2012 01:35 AM
bigdaddyII
07-13-2005 10:49 PM
SimCity
11-06-2003 11:13 PM
Quick Reply: noise coming from front end
