6.4L tq vs 6.4L Maxforce 7 in the International trucks - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-07-2006, 07:56 AM
powerdog powerdog is offline
powerdog is starting off with a positive reputation.
It is funny the 6.4L Maxforce in the int. trucks has a peak tq rating at 1400RPM’s vs. the 6.4l tt in the super duty at 2000RPM’s. This tells me that ford chooses to keep max tq at close to 2000rpm’s for drive train durability or for better performance.
Old 12-07-2006, 08:56 AM
origcharger origcharger is offline
origcharger has a good reputation on FTE.origcharger has a good reputation on FTE.
Yes, they did that on the 6.0/VT365 also. It leads many to falsely believe that the peak torque is at 2,000 becuase its a V8 and incapable of producing low end torque similar or better than an inline engine.
Old 12-07-2006, 09:06 PM
duramaximizer duramaximizer is offline
duramaximizer is new and has a neutral reputation at this point.
I read somewhere that the 6.4 maxxforce only uses 1 turbo also. Anyone got the info on that?
Old 12-08-2006, 01:50 PM
IHbase's Avatar
IHbase IHbase is offline
IHbase has a good reputation on FTE.IHbase has a good reputation on FTE.
Quote:
It is a trade off and for the consumer market, everone thinks they need 300+hp in a truck. But in work applications, torque seems to be a lot more important. Witness the high torque low hp formula in all heavy truck and tractor applications.
As for your drivetrain durability point- not so much an issue. Engine manufactures have been limiting torque in lower gears for just that reason for years and maping higher torque in higher gears. So, in theory, they could map around crazy high torque numbers by limiting output in certain ratios.
-Mike
Old 12-08-2006, 02:10 PM
kw5413's Avatar
kw5413 kw5413 is offline
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
Welcome to FTE and the 6.4 forum IHbase
Please take a few minutes to read up on our site guidelines.
http://www.ford-trucks.com/guidelines.html
</WMFILTERED>
Old 12-08-2006, 07:19 PM
jmcholden jmcholden is offline
jmcholden is starting off with a positive reputation.
It would be realy great if they would let the customer map thier own torque and HP curves according to each persons needs, or at least let you choose from a few?
-Mike
Old 12-08-2006, 08:10 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is online now
EpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant future
Isn't that what the chips or programmers are supposed to do? I don't know as I've never had one before. If I remember right, on some systems you can choose different levels of power, shift points, etc.
EcoStroke V6 Ranger Powerstroke VT275 Maxforce5 houseofdiesel 1999 to 2016 Super Duty 15 07-07-2014 04:16 PM
powerstroke 6.7 vs maxforce 7 International breaks it down SANDDEMON08 6.4L Power Stroke Diesel 10 12-22-2013 11:44 PM
International Vt365 Vs. Ford 6.0 Ecm Programming 6LPSD 6.0L Power Stroke Diesel 8 01-31-2008 10:21 PM
5.9L V8 vs 5.4L V8 LPD111 Ford vs The Competition 40 12-08-2003 12:46 PM
460 port polished extreme cam HP TQ?, 6.8L V10 HP TQ, PSD TurboD HP TQ, 460 TurboG HP 74crwcb429hibPS4spd 6.0L Power Stroke Diesel 0 07-09-2003 02:02 AM
Tags
64, 64l, engine, force, international, map, max, maxforce, maxxforce, output, torque, truck, turbo, v8, vt365
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
