distributor not spinning - Ford Truck Enthusiasts Forums
Old 12-06-2006, 08:39 PM
thenipster thenipster is offline
thenipster is starting off with a positive reputation.
In the past I had to replace my distributor 'cause the rotor stop spinning. The shaft had become sheared somehow. While driving recently my truck had just stopped firing and quit. I thought the same thing happened......so I changed the distributor. The new distributor didn't spin while cranking the engine. I checked the old distributor and it was ok. The truck is a 1985 F150 with a 300 inline six. Anyone with any ideas as to what the problem may be?
Thanks a bunch in advance.
Help.....someone Please!!
Old 12-06-2006, 09:09 PM
Bdox's Avatar
Bdox Bdox is offline
Iconoclast
Bdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputation
The gear on the camshaft may have stripped. Could be wear or possibly the oil pump has siezed.
Old 12-06-2006, 09:11 PM
pchristman pchristman is offline
pchristman is gaining momentum as a positive member of FTE.
Old 12-07-2006, 10:39 AM
SR_Crewchief SR_Crewchief is offline
SR_Crewchief is starting off with a positive reputation.
I willing to bet that you've stripped the timing gears. Pull the distributor and have someone crank the engine while your looking down the hole. If the gear on the cam that drives the dist isn't turning it's time to pull the timing cover. either the timing gears have failed or the cam has failed.
Old 12-07-2006, 05:21 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
I just helped a guy on this site with the same problem. His timing gear was minus a few teeth. I will see if I can find his posts.
Old 12-07-2006, 05:30 PM
mantta's Avatar
Find the posts by ddsvi, they will guide you through the process.
do you gave to tune the pro comp distributor to get it to run right? Jonnylightning 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-29-2015 04:50 PM
Need to vent earthquake68 1973 - 1979 F-100 & Larger F-Series Trucks 28 03-20-2015 12:27 AM
1986 ford f150 not firing ewhit8 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-20-2014 02:53 PM
Distributor Cap Questions LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 12-23-2012 11:11 PM
Distributor oiling. flipklos Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 9 02-14-2010 08:39 PM
Tags
300, 49, 49l, cam, distributer, distributor, f150, ford, inline, model, rotor, spinning, stripped, thenipster, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
